Dell 5100CN Not printing magenta - Office Equipment & Supplies
  • 2 more comments
  • Mikesw940 May 22, 2008
    My Dell 5110CN stopped printing yellow, even with a new Dell cartridge. No error codes showing. Ran all tests available; it passed each but did not print yellow. Dell support suggested replacing cartridge, which I did to no avail.
  • DBGuy01 Jun 11, 2008
    Printer does not print magenta no matter how many times I run cleaning cycle. Cartridge recently replaced. Other colors and black OK.
  • jrichardson8 Jul 22, 2008
    cleaned heads replaced cartridges and magenta will not print
  • Anonymous Apr 24, 2009
    relatively new cartrige, won't print magenta
Dell 5100cn won't print yellow. No error messages except "replace imaging drum soon". Replaced yellow cartridge, cleaned yellow, etc. Still not working
Posted on Nov 12, 2010
Corysf62
  • 188 Answers
SOURCE: Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Posted on Oct 30, 2008
Ajkill
  • 2035 Answers
SOURCE: Dell 920 printer won't print magenta.
There are chances the magenta ink got over or its dried :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer. try this if this did then heat the cart cartridges walls with hair dryer for 2 min then insert it back and check if it works:
Posted on Feb 24, 2009
Corysf62
  • 188 Answers
SOURCE: Dell 5100cn - Magenta color on all prints
Hi 56tbird.
The answer you got from Dell was partially correct.
It is the Magenta Developer that is causing your problem, however, you can replace this part for less then the printer if you do the work yourself.
I have successfully instructed other on replacing the developer units, although you will have to procure the part.
This is one of the 4 color assemblies you see when you remove the imaging drum.
The part number for the Magenta Developer is M6090
The first thing to do is price the part. I usually suggest doing a google search for the part number. you will find many resellers that way.
you might also try a search on Ebay for the part number as well.
If you decide to purchase the part, if you somewhat mechanically inclined, you should be able to replace the part without a problem.
I can give you detailed instructions on how to change the developer if you decide to go that route.
Thanks,
Cory
Posted on Nov 04, 2008
Corysf62
  • 188 Answers
SOURCE: Dell 5100cn
deatech,
I am going to answer this even though there was no reply to my clarification report.
No, it is not a HVPS problem. This is a magenta developer problem. The magenta developer for some reason has the highest failure rate of all the developers, including black. Perhaps because there are more shades of magenta in color prints.
Since you changed the toner, we can assume you are not out of magenta, but it is possible that you did not run a developer cleaning in the maintenance mode on the magenta developer.
If the magenta toner had been allowed to run out all of the way, a developer cleaning would allow the toner auger to move fresh toner from the toner dispenser, through the feed tube, into the developer.
If you have run the developer cleaning, and you can see that there is magena toner on the magenta developer ( for clarification, the developers are located behind the imaging drum. remove the drum to expose the 4 developers ), then the developer itself is defective.
Good luck.
Cory
Posted on Nov 22, 2008
kakee
  • 1269 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
Pages come out pink only when printing in colore
The magenta developer is bad.
The developer drive on this printer rotates in both a clockwise and a counter clockwise direction to turn the developers.
When printing black, ( i cant remember which direction it turns, ) only the black developer turns.
When printing color, the developer drive turns the opposite direction, engaging ALL 4 developers.
( the developers are the multi colored bars you see when you remove the image drum unit.)
This is why you do not get the pink output when printing only black.
your choices are to set the printer to only print black and white. ( you can do this in the printer properties for your print driver). or you will need to replace the magenta developer.
Feb 07, 2011 | Dell 5100cn Laser Printer
My dell 5100cn printer is not printing red tones at all. Everything comes out in green tones. Has new toner cartridges and drum. What can I do?
The M6090 Magenta Developer is failing. It has lost it's magnetism. So the toner isn't ready to be transferred.
The Cyan Developer G6593 or Yellow Developer H6682 may be failing too, because it can't dependably hold all it's toner. One of those is probably bad too.
Whit
Item, Inc
Aug 17, 2010 | Dell 5100cn Laser Printer
5100cn - verticle line omitted on magenta test page
sound like the drum could be the problem have you replaced that? if the fuser was the problem it would have the toner but would not have been fused or had marks on the page. this would be my best on this issue
Feb 24, 2009 | Dell 5100cn Laser Printer
No magenta
It sounds like the problem is either the drum or the megenta developer assembly. The drum is a consumable you can replace. The other usually involves a technician...in other words, very expensive.
Jan 28, 2009 | Dell 5100cn Laser Printer
56Tbird
not a problem at all.
This should fix your issue. I won't say it is a common failure, as the machine overall is very reliable, however for this problem the magenta developer is the most common failure for the 5100 and 5110.
Check your email shortly for the document and additional comments.
Please take a moment to rate this solution,
Thanks,
Cory
Nov 05, 2008 | Dell 5100cn Laser Printer
Hi 56tbird.
Thanks,
Cory
Oct 31, 2008 | Dell 5100cn Laser Printer
Color Faded
5100cn Printer
Print Quality Issue
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Service manual
When you say the gears are not messing, what exactly do you mean.
Do you actually hear gears grinding, or are you just having an issue with magenta not printing properly.
if you hear grinding, where is the noise coming from? at the top right corner by the toner, or on the right side in the middle?
In either case, if you actually hear a grinding noise, this would require replacement parts to repair as these are not consumable user replaceable items.
Sep 04, 2008 | Dell 5100cn Laser Printer
Dell 5100cn
deatech,
Good luck.
Cory
May 05, 2008 | Dell 5100cn Laser Printer
Magenta colour comes through on all prints right across the page, it is faded but is still clearly there. I can temporarily fix problem by using the printer menu to clean the magenta developer, but it...
We have over 50 of these printers and a few have had the magenta bleeding problem. On everyone of them the problem was corrected by going to the clean developer function under Maintenence from the Menu and choosing to clean the magenta color. Usually have to run it a couple times but it has always corrected the problem so far.
Mar 29, 2008 | Dell 5100cn Laser Printer
894 people viewed this question
jasbo
jasbo
