Question about Smeg 18 in. DWI410 Built-in Dishwasher
Hi, our dishwasher doesnt seem to hotup nor does the tablet seem to drop and program seems to stop and when you open the door the glasses sigh just flashes?
SOURCE: IZZI Built-in Dishwasher
managed to get behind the facia. cleared the pipe by a combination of blowing and sucking (into a fixed on pipe)
Dishwasher is working fine now......thanks.
Posted on Mar 20, 2008
SOURCE: SMEG DISHWASHER - SUPPLIER CODE : SA8605XTD
Hi, I don't usually put the tablet in the door holder. I just place it in the bottom of the washer . I aways am concerned that there will be soap residue. So this way utensils are getting washed as soon a the washer commences .I usually scrape debris off plates and utensils before I put them in the dishwasher. This works well. Hope this works well for you. Teresa
Posted on Apr 19, 2008
SOURCE: Smeg Dishwasher STA945.1, flashing lights
have you check the pipe's for blockage
Posted on Sep 11, 2008
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
  • 9 Answers
SOURCE: Baumatic BDW5
http://www.manualnguide.com/dl/12334/ Here is the online manual
Posted on Jan 25, 2009
Hotpoint DF52 stopping after 4 on the timer
Replace the timer control is my advise
Jun 27, 2017 | Dishwashers
Miele Turbothermic G579SC Dishwasher Intermittent Problem Dishwasher works fine on approximately 30 per cent of times it is used. This percentage seems to be about the same whatever program is selected...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 07, 2011 | Miele Dishwashers
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Leaking from the door
Hi there. Have you started using new tablets. Ours does the same thing if we use certain tablets. Ours is too much soap suds coming over the bottom tray, so If you have filled up all your other fluids and then use a 3-1 tablet it may be producing too much suds. These then overflow out of the door and drip out at the bottom of the door.
Hope this helps! It seems weird I know!
Don
Feb 15, 2009 | Maytag Dishwashers
Door opens beyond position parellel to floor
Hi dougisommer
I'm Harvey the Master Plumber.
Your question is: The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
You may need a sevice tech for this. The 'door catchers' on the sides of the unit can only be accessed after removing. Not a job for the inexperienced.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
BEKO D 2731 FW Dishwasher Problem
possibly due to water in the sump tray. tilt machine back at 45deg and see if water runs out. if it does and you get rid of the water that way, then the machine should operate. if it reoccurs, then you have a leak
Jun 21, 2008 | Dishwashers
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Indesit DG 6100
the seal on the top drawer is damaged
Oct 05, 2006 | Indesit 24 in. D61 Free-standing...
Open Questions:
See all Smeg 18 in. DWI410 Built-in Dishwasher Questions
Smeg 18 in. DWI410 Built-in Dishwasher Logo
50 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
