Question about Brother CE4000 Computerized Sewing Machine
Brother CE4000 E4 error message, machine will not work with Foot Controller attached.
    Genius:
  • 1,788 Answers
Get a copy of your manual at brother-usa.com for free. If, you have one already, look on page 62 and it tells you what the problem is.
Posted on Sep 12, 2010
I took apart my sewing machine, Brother CE1100PRW, to clean, and "Error 1" would not go away, please help.
Brother says:
The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
An E1 message appears on the panel Brother
Apr 13, 2018 | Brother Sewing Machines
E1 error brother ce 4000
Hi.
You can get the E1 error if the presser foot is not down. If you use the walking foot attachment it can keep the foot from coming all the way down.
Apr 08, 2017 | Brother CE4000 Computerized Sewing Machine
What is error F5 on my brother es 2000
Start button on machine was used while foot pedal is plugged in.
Manual says just use one or the other to operate the machine.
The error is E5 All the errors on this machine are "E" errors.
Cheers,
Kelly
San Diego, CA
Apr 26, 2014 | Brother CE4000 Computerized Sewing Machine
The needle is skipping stitches in every position, how do I correct this issue?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 26, 2013 | Brother CE4000 Computerized Sewing Machine
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
Error E6 and E!
the needle needs to be changed since it's hitting the walking foot
also the machine could be out of time since the needle is hitting the walking foot
it needs to be serviced
Jan 24, 2012 | Brother CE4000 Computerized Sewing Machine
I am getting error message E4 when foot pedal is plugged in. Unplug the foot pedal and the machine goes back to normal with the exception that you really can't sew without the foot pedal.
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
Sep 10, 2010 | Brother CE4000 Computerized Sewing Machine
I have a brother ce4000. I am getting an e1 message every time I push the pedal. I have the foot in the down position. I have sewed something heavy and the automatic stop mechanism has been tripped. How do...
Page 62 of the manual does not have any reference to E1 requiring a re-set.
E5 does state to unplug the foot control and use the start-stop button. This might work as a re-set.
Feb 25, 2010 | Brother Sewing Machines
Brother CE4000 Computerized Sewing Machine Logo
295 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
