Question about ICOM Informatique BP-180M, ICOM,IC-W31A.,IC-W32A,IC-Z1A,IC-T22A,ICT42A, 7.2v 1000mAh NiMH 2-Way Radio
IC w32a has been apart about 3 times to re solder the power plug ,this time I put it back together and the the 2m band wont transmit but for a second then off.Nearby radio will pick up the brief transmission.Scaning up I found it starts to transmit solid at 375.000. 440 seems to work fine.
Thanks for letting me post a question.
After taking it apart again I found a pin on the lower board socket that got bent over on reassembly........
Posted on May 14, 2008
Instrument cluster black
If you have the 3-Panel Digital Cluster, with the Fuel on the Left.., Speed in Center.., and Odometer on the Right.., and the Cluster is going Wacky.., works one minute then craps out the next.., take the dash apart and remove the Digital Cluster. Take your time when unplugging the harness behind the cluster, use a mirror if you have to.., to unplug it correctly.
The problem with this Digital Display is the Solder Connections.., at the 14-Pin IC Chip.., which is directly behind the Odometer Display on the main Circuit Board. When you get the Cluster removed.., again.., take your time.., and take the cluster apart.., so you get the main circuit board out. The 14-Pin Integrated Circuit (IC) Chip is marked with an IC2 on the main board.., which as mentioned is behind the Odometer Display. The IC Chip is usually Black in Color.., and is '@' 1/4" x 3/4" You will need a Soldering Iron.., @ a 30 watt with a pointed tip.., don't use a Soldering 'Gun'., too hard to use and too hot.., you don't want to cause yourself more problems by messing up the board circuit tracks by overheating them.., so it's best to use a smaller iron. It is a good idea to have some fine strand solder on hand.., but you should not need it.., all you want to do.., is to 'Re-Tin'.., or 'briefly' melt the Solder at all 14-pins of the IC Chip.., on the back side of the board.., to Re-Flow or Re-Solder the Connections of that 14-Pin IC Chip to the Circuit Board. That's all it is..!!!
I just repaired my 1991 Olds Cutlass Supreme 3.1.., 3-Panel Digital Instrument Cluster in this manner.., and it has been "Perfect" for a month now..!!
Take your time.., get it all back together.., and my bet is that it will be good to go for many more years to come..!!
Good Luck.
Oct 10, 2012 | 1991 Oldsmobile Cutlass Supreme
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
Can hear sound but the screen is white
The tv Tuner signal board it is the causes and the problems,that the board where the incomming broadcasting signal cable wire plug into it.Fixed this problems before,many times before the small Mosfat 6 legs IC that regulator the voltages for the main CPU chip on the board it is dead that why the tv Tuner signal board it just have a blank and white tv LCD screen panel only have no video,but it have audio sound to the tv.This Mosfat 6 legs IC are surface mounted IC is very hard and almost impossible to replaced by a regular home soldering iron equipments,even if u somehow able to buy this Mosfat IC voltages regulater.If u have some mechanical skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.Will fixed this tv wright up.
Aug 06, 2011 | RCA L26HD31 26 in. LCD HDTV
The sound on my toshiba theater view wont work i checked both the speakers and they are fine. Is this a simple fix?
hi,
If speakers are ok then the sound output ic of your tv is faulty. If you have basic knowledge in electronics then you can replace the ic. You can find the ic by following the wires from the speakers. It will end near the sound out put ic. The ic will be fitted on an aluminum heat sink. Note that number of that ic and get a new one from the nearest electronic spare part shop.For replacing the ic you need some tools like screwdriver de-soldering pump soldering iron, solder etc. All these thing will get from the spare part shop, if you don't have the same.Be sure to open the tv only after half an hour after dismantling the power because electrolytic capacitors inside it will store the power for some time.
ok
Jun 09, 2011 | Toshiba 50A50 50" Rear Projection...
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Tv turned itself off. turn power back on, picture
Your TV is experiencing a convergence issue as indicated by the 3 blinks. The only way to fix this is replacing the convergence ICs. It is not a hard task to replace these ICs. You just need to know how to solder and work on printed circuit boards.
The convergence ICs are mounted on a large heat sink and are marked with codes starting with the letters STK and there are two of them. You need to replace both.
Look for the heat sink with two ICs mounted on it and check the markings.
Once found, cut the IC legs with a small side cutter and unscrew it from the heat sink. Remove the legs left soldered on the board.
Take note of the IC markings for ordering the right part and how it was installed. Don't forget to buy along with the IC a thermal compound.
Check the pico fuses on the same board. Most likely you will find a blown one. These fuses look very much like a resistor, not like the usual transparent fuse, and usually yellow.
Once you have the replacement ICs, put it on the board in the same way as it was installed before. Make sure the screw holes are aligned before soldering the legs into the board.
Put a reasonable amount of thermal grease/compound between the ICs and the heat sink and fix them with the screws.
Double check the board for any splash of solders that might cause a short circuit and damage the board.
Dec 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic TX-68PS12A Picture shrinks in vertical direction at top and bottom over period of 15 minutes until vertically compressed picture occupies approx 1/3 of the screen in a central band
Ur Vertical/Horizontal ic is cold solders,U know how to solders?Take the tv aparts use a back handle of the screw driver tabs around find out where V/H the cause resolder that.
Oct 22, 2009 | Televison & Video
My Alpine CDM 7871 produces no sound other than through the pre-amp outputs. As as a result the only sound I am receiving is from the sub-woofers in the trunk. None of the speakers within the cabin of the...
Your problem is the amplifier IC inside the unit. It is attached to the heat sink and soldered onto the main circuit board. If you have a soldering iron, solder, and solder wick (to remove solder from bad IC) you could do this repair pretty easy. You would need to disassemble the unit and remove the solder from the IC, then remove the IC from the heat sink and attach the new IC to the heat and put it back into the board and then solder all the pins of the new IC back onto the main board. After that, just put the unit back together just the way you took it apart. Just pay attention to where all the screws went and make sure you get them all back in the right places.
If you do not have the soldering equipment and are not comfortable with your soldering skills it would be better left to a service center to do this. Just about any service center would be able to do this repair for around $100. That should include the part and the labor. The price will depend on the service centers rates, but it is an easy repair that would require less than 1 hour of actual labor. Most shops will charge a minimum of 1 hour labor even if it only takes 15 minutes.
I have been repairing car audio equipment for over 18 years and can assure you that this is the problem you have, it is the typical symptoms for a bad amp IC.
Feel free to ask any other questions by just posting back on this thread.
Dave
Sep 20, 2008 | Audio Players & Recorders
Battery will not charge
Do you have a volt meter to make sure the plug is still good? did it blow a fuse?
Dec 17, 2007 | Compaq Presario M2000 Notebook
Radio Communications Logo
251 people viewed this question
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
BJ Russell
Steve
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
