Question about Asko T701 Electric Dryer
Asko dryer running but no heat after changing drive belt
  • Asko Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Asko T781 Electric Dryer
Asko t712c dryer was heating up but drum not spinning. Now not powering up at all.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 03, 2010 | Asko T712C Dryer
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Asko T700 dryer does not heat up, and start button does not work unless held down.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 07, 2009 | Asko T700 Electric Commercial Dryer
ASKO T731 Dryer - Air is not warming up.
same thing has happened to me...please help
Dec 05, 2009 | Asko T731 Electric Dryer
My dryer is not spinning
change the belt if you need help get the belt first thank you please rate me
Mar 12, 2009 | Asko T701 Electric Dryer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
How to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Nov 05, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Asko T701 Electric Dryer Logo
144 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
