Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Model ED2vhextoo1. the freezer is OK, except is frosting up. ref. has risen in temperature not cooling at all, no air seems to come out of the louvre on top left of ref. compressor seems to run all the time. louvre in back of freezer seems to be moving air. dosent seem to be a lot of lint biuld up in bottom around fins. took off long tin in back, under the ice maker, not a lot of ice build up there. Any other suggestions??
  • 878 Answers
SOURCE: Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. back.
Posted on Oct 21, 2006
  • 473 Answers
SOURCE: frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
  • 744 Answers
SOURCE: my freezers interior cooling fins are frosting,
Hello, this sounds like you have a blockage in the drain tube, remove panel back of may see ice build up...melt ice with hair dryer/heat will see a pan below evaporator...melt ice in pan...dry water up in pan with paper you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Aug 31, 2009
SOURCE: GS6NBEXRSOO model whirlpool gold 2005.
My freezer is working but my freige is not working what should I do
Posted on May 01, 2011
I purchased this Frigidaire freezer three years ago. Around a week ago, I noticed that the items I had stored in the freezer have begun to thaw slowly. Although the freezer is still "working", it...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
Jul 23, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
There is moisture in the freezer. it should be no frost ref but sometimes we can see frost in the freezer
Is the frost built up on top of old food packages compared to new packages? Old packages will develop frost. If the temperature of the freezer is correct that is just normal condensation in the unit. If your freezer is pack tightly then you need to arrange it so that air will flow freely through out the racks. Good Luck
Jan 07, 2011 | Refrigerators
Freezer frost then loss of cooling
There is a block of ice that is causing the air to not flow across the coils as it should. This is why the temp has risen. You can do a manual defrost by un-plugging the unit over night but I would call out a ref tech to check the defrost timer and the freon level. Hope this helps. Good luck. Please re-post with updates. Thanks cj2176.
Jul 13, 2009 | Fisher and Paykel Active Smart E522B...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
My Servis fridge/freezer sounds like Darth Vader
We had the same problem and discovered that the ice making device was "on" and we don't have it hooked up.  In the "on" position the pump begins to run but there is no water to pull so it sounds like breathing.  The ice making bar for us on our Jenn-Air is located near the ice trays and ours needs to be in the up position for off.  Hope this helps!
Jan 11, 2009 | Frost Freezer WCWO F15WA FREE - POCKET...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
My freezer dosen't work but the fridge seems to be O.K.or at least cold enough (Model BX2255W Manufacturing# P1196708WW) Ive vacumed underneath and adjusted both the freezer and refer controls. The fans...
Normally it is the temperature of the refrigerator that shows the first sign of a problem because the refrigerator is cooled by air from the freezer. Check the back wall of the freezer for signs of frost. If there is frost on the back wall you have a defrost system problem.
Jun 29, 2008 | Amana Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
