Question about BenQ FP757-12 17" Flat Panel LCD Monitor
No signal and no picture, is it dead?
Hi two days ago i noticed that my Benq FP757-12 is not displaying picture at all. I tried connecting it to my laptop computer and the only thing I get is a millisecond of screen display. Tried changing cable to no avail. It only blinks two to three times and remains black the rst of the time.
Is it dead? Is there anything that can be done with it to test?
please advise
Petar
IS A LCD FLAT SCREEN EASY TO FIX. THE LIGHT FOR THE START BUTTOM LIGHTS AND THEN THE SCREEN IS BLACK
Posted on Apr 11, 2009
Inverter is dead
Posted on Jun 08, 2008
Want to use BenQ m2700HD monitor to watch a movie. The movie is playing on a LG DVD player. I have used a yellow video lead from the DVD player in the past but it will not work on the BenQ
Not sure why it does not work, do you get message 'NO SIGNAL' on the screen?
You can try using component video instead of the composite video (yeallow RCA) which will give you better picture since it will be in the progressive scanning mode display.
Jun 25, 2011 | BenQ M2700HD Monitor
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
Hi - I have a 47" LCD and just a minute ago I heard a very high pitched noise coming from it. I was unable to turn it off so I unplugged it. I can turn it back on but the touch keys remain lit up and the...
Ur Main turner signal board is dead.Replaced this Tuner board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board. to replacement.
Mar 10, 2010 | Vizio VO47L 47 in. LCD TV
I have connected my Toshiba laptop to a benq PB6210 beamer but cannot get presentation on the screen. I need help
1) Turn off the BenQ power, before connecting your VGA cable to the Toshiba laptop.
2) Once your laptop recognises the BenQ unit, you then need to tell your laptop to send an output signal to the BenQ - you do this by pressing your 'screen output' button (this is usually one of the function keys and you may need to hold the key for 1sec). The output function key can choose either single VGA output, or both laptop screen + VGA output.
"If this has helped you, please rate this solution"
Dec 01, 2009 | BenQ PB6100 Multimedia Projector
DLP Projector connection to Laptop
you need to go to te control pannel and go to display settings then manually select the external monitor then hit apply it will open on your projector
Nov 02, 2009 | Office Equipment & Supplies
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
"No Signal" floating notice on Blue Screen - No other picture
If all connections and the tuner have the same issue, you either have a power supply issue or a bad digital board.
Mar 29, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
BenQ FP757-12 17" Flat Panel LCD Monitor Logo
258 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
