Question about Avanquest Computers & Internet
My deep scan will not finish running it gets to 99% and 489,000 sum files and stops, freezes up this is the 3rd or 4th time ive tried to run it , this version is fix-it utilities9, trying to run i think there maybe a virus of some sort , at the point it stopped a prompt came up somehting about sunbelt antivirus ,i wasnt aware of anything but fix-it being on my computer, or is that the problem
  • 428 Answers
Hello, Mark
Well we will be able to solve this issue. Its kind of a common problem associated with Sunbelt and Fix-it. Before going further I would like to know some details about your knowledge of computers and operating system. Because the steps I am going to describe here are technical and requires you to be an experienced user. You have to be comfortable of System tools and Utilities. Otherwise, I have to provide a more detailed solution. So, first I would like to answer a few questions to better understand the client and the issue.
  1. Are you a comfortable user with the Operating System?
  2. Which Operating System does your computer run?
  3. When did you observe that your PC has this problem?
  4. Did you do a Customized Installation or a Typical / Full Installation?
  5. Did you do Deep System Scans earlier?
  6. Did you Aware of the Fix-it utilities package and its available tools / utilities ? Hope you have read the Product guide and User manuals before using the Software.
  7. Do you have any other Anti-spyware / malware scanners running inside of your PC?
  8. What is the EXACT error message you receive? That is very important.
  9. Have you Installed or Un-installed any software recently?
Please include these information in your next reply. Otherwise you will not be able to get a Customized solution.
Symptoms:
  • Freezing the PC: 4 possibilities
  • Most probably because of the Invoke of Viper Anti Virus package. Its natural to stop at 99%, if so.
  • Unable to load the Sunbelt Component.
  • The required component is either missing or corrupt.
  • The Virus had jammed one of the components.
The solution may depend on your Answers
Possibilities:
  1. If you are a comfortable user with PCs, I can give you instructions to the point without going to a detailed description.
  2. The steps will depend on your Operating System.
  3. The first occurrence (date / time) is important. So that I will be able to be specific about whether there is a Virus Infection or Not.
  4. Depending on your Installation methods some components or packages may or may not have been installed.
  5. If you have successfully completed Deep System Scans earlier then it may be a Virus and it may have jammed the Viper package (Viper is the Sunbelt AV suite).
  6. Fix-it has many Tools and Utilities Integrated into their package. Such as Anti Virus Protection. They use Sunbelt's Viper AV suite. So you will not be able to see any Fix-it Anti Virus packages running. This is a very common confusion among users of Fix-it. But even other packages (all most every package) which are designed to do SYSTEM MAINTENANCE do include Alien Anti Virus Programs developed by other companies. It is a well known fact. So if you have chosen the Typical installation, it may not have been installed. But it will be available with the Full installation. If you have used the Customized installation, you had the ability to Control the Installation of the Sunbelt Viper as well as other Components (one by one). So now you have to be Aware whether you have the software or not. Please go into this location and check whether its available. C:\Program Files\Common Files\AntiVirus\SBAMSvc.exe or C:\Program Files\Sunbelt Software\VIPRE\SBAMSvc.exe. If it exists with files in it, you have that component. Otherwise you do not have it.
  7. If you have any single instance of an Anti Virus Suite Installed (or any malware or a spyware remover), please REMOVE it. Otherwise two applications will definitely lead each other to a huge Conflict. Because each will think and treat them selves as Viruses. You cannot run two suites simultaneously.
  8. You must include the message (error or warning message) with the next reply if you were not able to solve this.
  9. If you have Installed or Un-installed any software during this period, it may have altered the configuration of the Viper or might have Removed Shared Components. If so, you have to do a Repair Installation using Add or Remove Programs. Or you can do an In-place Upgrade (upgrading to version 10) but you may have to Purchase License.
  10. Have you ever CONFIGURED the AV suite which comes with Fix-it ?
Solution:
I have included Several solutions to the point form, in the Possibilities section. The problem is either you have Sunbelt Viper and it has a problem associated with or you haven't installed it. If it is available, you have to read the Message and you have to Paste it with your Next Reply. Then I can be specific. You have to use Windows Event Viewer utility to check for further errors associated with the Software.
How to:
  • Tap Win key of your Keyboard
  • Type in Run (if you use Windows 7, you can type in the Search box in the Start Menu - Not Windows Search)
  • If you use Windows 7, alternatively you can type this command directly into the Search box with the Start Menu and hit enter key. Chose to run as the Administrator. For other Operating Systems, get the Run box and type the following Command and Hit Enter key.
  • Eventvwr.msc
  • Go to the "Application" category.
  • Check Errors (red X mark) and Warnings (Yellow ! mark) related to this Software (Fix-it or Sunbelt Viper or SBAMsvc service). If you examine any, please include it to the next Reply - You can Ignore the Warnings. If the Service cannot Start (if you see any error like that) let me know. I will describe how to start a Service manually. It might be Disabled as well. If its Available however, you will see it running in the background and in the Taskbar (bottom right corner). You MUST use Task manager every time to check whether its up and running (Right click on the Taskbar and click on Task Manager. Go to "Processes" tab and check for Services such as SBAMsvc.exe).
  • Have you ever Configured the Anti Virus suite? That is a very important question. If you haven't worked with it, it may have Removed or Quarantined Viruses already. Or it may not know what to do. So please use Fix-it to Invoke it and Configure it. Ask me if you do not know how to configure the Viper AV suite.
  • If you examine that you have not installed it or something Jammed it, please do a Repair Installation. Insert your Fix-it CD/DVD and go to Control Panel -> Add / Remove Programs. Click on it and check whether the "Repair" or "Change" button Available (Or Change/Remove). If so, click on it and follow the Instructions to Install or Repair the Anti Virus Component. Otherwise you may have to do an Un-installation and do a Re Installation. Make sure that your are NOT Running ANY OTHER Anti Virus Suites.
Please feel free to contact me again. You have to reply if you are unable to solve the issue.
Have a good day!
Thanks for contacting Fixya!
-Lasitha (Microsoft Brand Expert)
Posted on Sep 06, 2010
My toshiba sata l675d freezes durring virus spyware scan
It seems that your computer is infected.
Step Followed:-
1. Click on start and type Run.
2. In Run box type Temp.
3. Select all and delete all files.
4. Follow 1st step and type %temp% and then follow 3rd step.
5. Follow 1st step and type prefetch and then follow 3rd step.
6. Follow 1st step and type appwiz.cpl (add and remove programs)
7. Remove unwanted software and all antivirus .
8. Restart the computer.
9. Download Malwarebytes from "http://www.filehippo.com/download_malwarebytes_anti_malware/download/d7670bee6c8cd1bb9341d9a1ffbe832f/ "
10.Scan your computer and remove the infection.
Thanks
Apr 05, 2014 | Toshiba Satellite L675D-S7052 Laptop
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
I use deep freeze 6.53 utility but I have to uninstall but the deep freeze program still running, please help me
you have to "thaw" deep freeze first:
push and hold down shift key then locate deep freeze icon (near the time in the bottom on the right) and double clic on it
clic ok (or enter password and clic ok) on the window now opened
then select "boot thawed" and confirm with "ok" and reboot PC
when Pc restarts you will see deep freeze marked by a red cross and now you have to run the original installation file (the same you used to install) and select unistall then PC reboot automatically
Feb 05, 2011 | AnchorFree Expat Shield
When I try to delete, move, or copy files in our out of my Buffalo HDD it stops responding and I have to close it. How do I get it to work normally again?
you probably have an old file (even hidden) that is causing this problem... go to my computer right click on this drive / properties/ select tools then select defragment now... this will take some time depending how big the hard drive... but right after its finish defragging run your virus scan on the drive only not the whole pc just that drive...(virus scan should catch unwanted files and remove) if you have a second virus scan software run that one too after the first one (note never ever run both at the same time) they will clash and your system will crash.... norton, mcafee, avg, kasper or avira are among the top.. after the scan run ... reboot........ try to copy move or delete
Nov 19, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
I have window s 7 on my pc & I have deep freeze 7 installed on it and i deep frozen my drive c,but after some virus problem my all drive have been deep freezed and now the deep freeze program not...
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Please comment if the information has been helpful. Thank you and regards.
Aug 25, 2010 | Computers & Internet
How to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
My norton 360 antivirus is saying that the pc security is at risk, and facebook and other websites are not loading properly. Ive tried turning on the sonar protection and it won't let me. need help!
did you run the check up or scan? you need to have full scan (deep) and check first cledan everything (old files, backups, tem. etc) then run scan
Sep 06, 2009 | Compaq Presario Notebook
Remove deep freeze
Try deleting it manually, go into safemode with cmd prompt only.
del c:\[filedir][filename]
it will induce an error next time it runs, but you can regedit.exe your way out of that one
Feb 27, 2009 | Compaq Armada M700 Notebook
Laptop freezes
"I never shut it off " Hope u r hibernating the laptop.. It seems that ur lap is junked with a lot of registery files and starup files.. so it takes a lot of memory to perform its operations and subsequently it hangs up.. and i hope u have installed norton anti viurs. this antivirus needs a lot of resources. better u install Mcafee. The best thing u can do is to install a fresh copy of windows. this will solve ur problem.. and remember keep the startup items to the min level.
Sep 03, 2007 | HP Compaq Presario V2555US Notebook
Computers & Internet Logo
298 people viewed this question
Top Avanquest Computers & Internet Experts
Joseph Hoffmann
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
