Question about Linksys Wireless-G WRT54GS Router (e125894)
Power Light blinking, no reaction...help?
I just plugged in my wireless router and all the lights turned on and remained solid except for the power light which is blinking rapidly. I have no idea what's wrong, it was working just a second ago, i just moved it to another area. Any ideas?
  • Anonymous May 16, 2008
    the wireless router will not run off the cable modem
  • 298 Answers
Its possible that the router is not getting enough power, make sure that the power adapter that it's using the original power adapter that came with I think its 12v 1Am, you can plug it to a different power outlet, or better yet plug it back to where it was plugged in before. If the light will go solid again the it could be a problem with the power that it's gettign. If it will still flash then it's a fault with the router's firmware. click here to see how you can resolve it.
Posted on May 19, 2008
I have a ATT 2wire modem and all lights are solid green except the wireless light and if theirs too much activity online then it shuts all the other lights off except the power light
Wireless is supposed to blink. Check to see if the power outlet might be giving out. If not, then you might have to replace the router.
Jan 13, 2014 | 2wire 2700HG-B Router (2700HGB)
Power was turned off to the house. When power came back the router is blinking blue lights and can't see the modem. Disconnected the computer from the wireless and plugged directly into modem and it's...
just as a guess try unplugging power to both modem and router, then plug only modem in first until connection light stops blinking and goes solid. then plug in router.
Dec 23, 2010 | Linksys WRT160N Wireless Router
My Linksys Wireless G Light is not on
Is the power light on the router blinking ?
If the power light is blinking and the WLAN light is not lit up then you will need to reset the router.
There is a small reset button on the back side of the router, where you connect the cables.
Press it and hold it down for 30 seconds. You will need a pen or paper clip.
Release the reset button and wait for 1 minute. Make sure that the power light willl be solid on the router.
Once the power is solid and steady, unplug the power cable of the router. wait for 5 seconds and plug it back in.
When you reset the router, it will come back to the factory default settings and you will need to set up the router again.
Click here for step by step instructions to set up the router.
Oct 03, 2010 | Linksys Wireless-G WRT54G Router
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
WRT610n router power led light blinks and i cant
If the power light is blinking on the router , then it might not be working properly.
You will need to press the reset button on the back side of the router for 30 seconds. release it. unplug the power cable. plug it back in. wait for a minute and check if the power light is solid.
If not then try to reset the router again.
do the same thing and check if the power light is solid.
If the power light is solid then you will need to set up the router again.
If the power light is still blinking, then connect the computer to the router and check the IP address on the computer. If the IP address is 192.168.1.100 then try to open the set up page of the router and check the settings of the router.
Click Here for step by step instructions
Dec 01, 2009 | Linksys WRT610N Wireless Router
Solid red power light
pls check the power supply this happens when the router's supply is faulty or the power outlet in WALL ,
otherwise try this see for RESET button on the back of Router press it for 30 SEC when ur router is ON and it will resolve for sure let me know if it doesnt solve i can help more
RATE ME WELL !
Regards
Zohail
May 17, 2009 | 2wire (1000-400108-001) Router
No lights on except power light.
The firmware has been messed up. DDWRT might be incompatible with your router. I would highly recommend to reload the factory firmware or the latest firmware from Netgear's website. Loading 3rd party firmware will void the warranty of your device.
May 09, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Linksys Wireless-G WRT54GS Router (e125894) Logo
169 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
