Question about Whirlpool Duet GHW9150P Front Load Washer
Wont drain clean out filter and leaking from the bottom
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Plug off the wall & look underneath, a hose may have come loose. Check, replace or fasten.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 13, 2008
Every now and then it leaks
Look at the bottom inside, there is a drain which can collect too much dirt and then stops up.
Apr 18, 2014 | Frigidaire FFBD2406NB Built-In Dishwasher...
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
Water wont drain, water leaks out of pump and from the front of the dishwasher
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 01, 2011 | GE Nautilus 24" Built-in Dishwasher
Drain wont drain on a epic washer where is the drain filter located at
The drain filter is located in the pump behind front bottom panel. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly.
Nov 14, 2010 | Maytag EPIC MFW9700S Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
I have a dishlex global 450 and it shows ND. what does this mean?
Hi and welcome to FixYa,
Offhand, error message "ND" refers to "No Drain" and therefore would require that the drain system be checked, cleaned and inspected for any faulty components. Normally, there would be a drain filter, a sump or sorts, a valve, an impeller and a pump that leads to the drain hose. Access to these components would be through removal of the bottom/kick panel. Further the presence of water at the bottom of the dishwasher indicates that the water is not being flushed/drained out but is leaking from any of the above.
Unfortunately, this is a very messy job.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 15, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Drain Pump Filter Leaks on LG TROMM WM2277HW. Has a drain hose and a drain pump filter accessing from the front bottom left. Ever since I first took the filter off to clean it has been dripping constantly....
I had to remove the two little plastic tabs that prevent you from tightening the filter plud too tight. Grind these two tabs off and you will find youare able to tighten the pluf just a bit more and it will no longer leak.
Feb 23, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
