Question about Vacuums
I received a new circuit board for a Paramount DBL-2000-MS electric fireplace, but not sure where to start looking for it.
Its on the back panel of the fireplace...take all screws off back panel and its mounted on the other side...be sure to put you wires back in the PCB as they are on the old on!!!
Posted on Nov 24, 2010
Schematic m12 circuit board
Also looking wiring schematic M12 Milwaukee charger
Sep 27, 2016 | Milwaukee tools Milwaukee Electric Tool -...
The dirt sensor light stays green. It won't turn red, even when I know I'm picking up a lot of dirt.
The Board(46851083) is No Longer Available
The EDF Duct (47823004) EDF= Electric Dirt Finder is $20.40 from
http www searspartsdirect com model part u6485900 0517 0645000 50039309...
You can test the board by crossing the 2 connectors to "close" the circuit for the mic (small black and blue wire) while vac is running and light should go to red every time you complete the circuit. WARNING: There will be exposed electrical points on board that could cause an electrical shock!!! or damage to board if not just crossing mic connections.
Jan 22, 2016 | Hoover U6485900 Bagged Upright Vacuum
Getting an H97 error code on a Panasonic micro wave, I believe I am having an inverter problem
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE: DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used. H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
Hope this helps.
Apr 28, 2011 | Vacuums
Dyson dc 15 brush roll not spinning. motor is good, upper switch is good.
Open the right side of the vacuum with a hex head screw driver. There are 4 screws. Inside you will find a circuit board.
1. Make sure the varistor (S20K150) is not blown, these models seem to have an issue with this. It is a flat blue "quarter" looking component near the top edge of the circuit board.
2. At the bottom of the circuit board are two white wires connected via push on connectors. Remove these from the circuit board by sliding them away from the circuit board. Power on the vacuum and engage the drive button. If the lower motor still does not engage check step 3.
3. A blue and yellow wire runs off the bottom end of the circuit board. These are the wires powering the lower motor. Check continuity with a multimeter and make sure they are not broken. I have seen where these wires will break as they run through the housing of the vacuum. If they are broken, replace them with any wire of the same gauge.
Dec 15, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
I have a 9068G and when I plug into the electrical outlet and press the "on" lever, I get nothing. The machine actually quit one time while I was vacuuming. Is there a fuse problem or a reset button? ...
There is no reset button or fuse, yo have a clog / reduced air flow, causing the motor to over heat and turn off. First change the bag, then remove the wands and carpet tool from the vacuum. See if the machine turns on. If not the main motor will need to be replaced. If it turns on and you have suction, check the wands or carpet tool for a clog.
Apr 16, 2010 | Samsung Quiet Storm 9069 Vacuum
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
My EL7020 so call Electrolux!
Check the electrical connections between the hose and the body of the machine, and also the wand connections all the way to the power head. Sometimes a faulty connection can send a false "off" signal back to the main body of the machine, and turn it off; but usually it will restart if that's the case. It sounds like you have a clog somewhere which is tripping your motor's thermal cutout, but you did say there are no clogs... so if you have full suction all the way down to the powerhead that's not the issue. You could have a faulty thermal switch, but I think the likely cause is, as usual; the sumo board.
Good luck. Sorry I didn't have a more concise answer for you.
-R
Dec 06, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Z8240 Cyclonic Bagless Vacuum Cleaner
Be sure to check the hose , wands and power brush for obstructions as well.
If there's a burning hair electrical odor then it might be toast.
i despise bagless vac's as they always wind up being more maintenance and expence then bagged vac's.
Good Luck and let me know what you find out.
Oct 08, 2008 | Vacuums
Not spraying
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
another is the spray nozzles are clogged.
Jun 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Accidentally plugged into 220 volt outlet
The wiring diagram isn't showing a fuse, but there could be one on one of the circuit boards. Maybe the converter is bad. You will just have to take it apart and look it over. Maybe this pic. will help:
Nov 05, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
259 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
