Question about Maytag Dishwashers
I have a maytag MDB2200AWE DISHWASHER I THINK ITS A 1999 THE BOTTOM ARM DOES NOT SPIN FREELY IT GOES FOR ABOUT 1/2 A REVOLUTION THEN STOPS, WHEN I MOVE IT BY HAND IT MOVES FREELY FOR ABOUT HALF A TURN THEN GETS HARD TO MOVE, HOW DO I FIX THIS ,AND HOW DO I GET THE ARM OFF TO SEE IF ANYTHING IS JAMMING IT UP
  • 11 Answers
SOURCE: water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Posted on Mar 22, 2007
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
  • 105 Answers
SOURCE: dishwasher not cleaning
hello kiwi
check the water level in machine this may be low due to pressure switch not sensing correct level try blowing back through air tube to clear any water from tube then try again
quick way is to start machine and when in wash mode check water and position of arms then add a litre or so of water in mid wash then recheck wash arms if they are now moving then you have water level problem
Posted on Feb 24, 2008
SOURCE: Upper washer arm not rotating on KitchenAid dishwasher
Make sure that the top rack is pushed all the way back, before you close the door to switch it on. Look at how it rests in the connection in the back. You'll see what I mean. That's most likely the issue.
Posted on Feb 29, 2008
SOURCE: bosch dishwasher arms dont spin, but turn freely
How do you know the arms are not moving? They are spun by the water jetting through them and they may be blocked. They just pull out and clip back in so run some mains water through them. Also if you put dishes or trays that are big they can obstruct the arms so give them a spin to see first.
Posted on Sep 05, 2008
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
Kenmore Dishwasher: Our dishes are not getting clean anymore.
This sounds like the sprayer arm isn't rotating freely.
Open the dishwasher and pull the bottom tray forward (remove it if you like)
Reach in and try to rotate the sprayer arm. It should move freely. If you give it a quick flick, it should spin around at least one full revolution before coming to a stop.
Sometimes these become blocked by dishes or plastic bags in the bottom of the dishwasher, other times they simply wear out and you'll need to replace the arm assembly. When I replaced this for our GE dishwasher this spring, the total cost was around $38 for the parts. The replacement took less than 5 minutes, with no tools.
If you want help tracking down replacement part numbers or a source to buy them, comment back here and I'll google them up for you.
And of course, if this helps you, please be sure to hit the thumbs-up button for me!
Dec 14, 2009 | Kenmore Dishwashers
Our whirpool dishwasher seems to be cleaning the dishes here and there, missing some. The top shelf of the dishwasher does not seem to be cleaning at all. Also the soap dispenser does not seem to be quite...
This sounds more like the sprayer arm isn't rotating freely.
Sep 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Bottom Washer Arm Problem
Hi Karen P The bottom arm ( well all arms really)is rotated by the water pressure created by the main pump. The bottom arm should spin freely when rotated by hand. If not, then the bush (or plastic bearing) may be worn or sticking. These parts are fairly inexpensive (at worst a new bottom arm will be required). Contact your local Maytag spares supplier and ask for a Bush repair kit for the bottom arm of your model. Regards
Aug 20, 2007 | Maytag DWU9962 Dishwasher
Water not going through spray arms
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Dishwashers Logo
66 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
