Question about Toshiba MD13M1 13 in. TV/DVD Combo
Manual for DCFL20S Toshiba Remote Control
I just bought this remote control to replace the original, but it is not working and the manual was not included.
Is there a way to program it to make it work, or it should work as soon as I put the batteries in?
Thanks.
  • Daniel Martinez
    Daniel Martinez May 11, 2010
    Magola:
    1st. Yes you do need FRESH brand new batteries!
    2nd. there are two types of r/c [remote control]
    [one]-you look up the codes in a book and follow directions to input into r/c so that it will control your machine.
    [two] this r/c is called a "Learning" r/c because you MUST teach it the codes to control machine. You MUST have your original r/c because u face each control to itself then u press the code from the original to the "learning" r/c. From then on, u can control with the new or "learning" r/c.
    If you brought a "learning" r/c ,then u MUST have the original, in working order & with a fresh new battery.
2 Suggested Answers
  • 901 Answers
SOURCE: TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
Posted on May 24, 2010
I bought a replacement remote for Toshiba TV and it was the same model number CT-90325 same as the original. but it won't operate the TV, does it have to be programmed to the TV somehow?
Sounds like the manufacturer did an upgrade. You can look up the remote control codes for that TV. Turn the TV power on. Then using the codes you found set each one into the remote you have and check the functioning by trying to turn the TV off. If you are unable to see instructions for setting the codes into your new remote, or if they weren't supplied by the seller, you'll have to find it's manual online and follow those instructions. It could be that Toshiba used the same control model for more than one TV set model. Often just putting in batteries will work but when it doesn't you have to treat the remote as a universal remote. If you can't use the primary unit setting to work you can try to set it up as an"AUX" unit as you would do for a second TV.
Dec 20, 2016 | Televison & Video
No remote for Emerson # LE320EM3,how do you turn tv on.Has no power button
Look just inside the rear with a mirror. Sony hides them there as well.
EMERSON Replacement Remote Control for LE320EM3 ... - Amazon.ca
https://www.amazon.ca/Replacement-LE320EM3-LC501EM3.../dp/B00FKH6ME6
  1. Cached
EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3: Amazon.ca: Electronics.
EMERSON Replacement Remote Control for LE320EM3, LC501EM3 ...
https://www.amazon.com/Replacement-LE320EM3-LC501EM3.../B00FKH6ME6
  1. Cached
Find helpful customer reviews and review ratings for EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 ...
Amazon.com: Original New Remote Control / NH305UD: Home Audio ...
https://www.amazon.com/Original-New-Remote-Control-NH305UD/.../B015IFY96W
  1. Cached
Original Factory Remote - No need for programming it just works! Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, ...
Emerson LE320EM3 LE260EM3 Remote Control and Manual ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
  1. Cached
EMERSON LE320EM3 LE260EM3 REMOTE CONTROL AND MANUAL in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Accessories ...
Remote Control for Emerson TV ' eBay
www.ebay.com/bhp/remote-control-for-emerson-tv
  1. Cached
  2. Similar
Original New Remote Control / NH305UD by Emerson. Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, LE320EM3, ...
Emerson TV Remote Controls ' eBay
www.ebay.com > ... > Emerson TV Remote Controls
  1. Cached
www.newegg.com > ... > Audio / Video Accessories > Remote Support Inc
  1. Cached
  2. Similar
Buy EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 with fast shipping and top-rated customer service.
Redi-Remote EMERSON Replacement Remote Control for ... - Sears
www.sears.com/redi-remote-emerson...remote-control...le320em3/p-SPM925361391...
  1. Cached
Aug 23, 2015 - EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3. Emerson TV Remote Control. Emerson LE320EM3 Google Search
Nov 24, 2016 | Emerson Televison & Video
How do I get a manual for Toshiba remote controller model CT 90302
Hello
This remote control is for use with Toshiba 22AV500U TV. It is originally coded to use with this TV, yet other TVs also can be programmed with this remote contorl. There si no specific user manual for this remote control itself. All codes and proceedings are with the user manual for the above mentioned model Toshiba Tv. If you haven't that manual, send your email address to me by Fixya. I'll send a copy of that manual to you by return mail. Or go tho this link from where you can download the above said TVs manual for as PDF format. OK
a248.e.akamai.net/pix.crutchfield.com/Manuals/052/05222AV500.PDF
Sep 01, 2011 | Toshiba Ct-90302 Remote Control
I need to purchase a remote control for our Toshiba DVD/Video player. Model # MD9DL1. Thanks. Sandra
You can purchase it at the link below.
http://www.replacementremotes.com/TOSHIBA/Buy-DC-FL20S-DCFL20S-BZ614254-TV-DVD-Combo-Remote-Control.html
Jul 20, 2011 | Televison & Video
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online...
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 17, 2011 | Toshiba Se-r0177 Remote Control
Toshiba tv/vcr remote code.
Ok, try using the guide, there you will find the codes, if you dont have one try going to a local store that sells your product.
Dec 10, 2008 | Toshiba CT-90157 Remote Control
Remote control SENSOR not working
This could be a fault with your remote control. It will need checking by a Television Technician.
You can clean the remote control yourself if you are careful. You will need a spray can of Servisol IPA 170.
  • Carefully split the remote control unit along the seal between the top and bottom of the unit.
  • Carefully notice how you then dismantle the inner components. (I lay the components out in the order I take them out of the unit).
  • In a logical order spray, clean and dry each part.
  • When you have cleaned all the components, reassemble in their reverse order of the way you dismantled the unit.
  • Fit new batteries and test the remote control.
If this fails to solve the problem, you will have to take the remote control to a Television Technician for testing.
If the remote is found to be beyond repair, visit www.semenedis.com who may be able to supply you with a replacement remote control. I trust this information will be of help to you.
Dec 04, 2008 | Toshiba 32A60 32" TV
Remote Control not working
you can easy check if you existing remote really work just look on the IR led with a digital cam and u will be able to see the led flashing
Feb 05, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba MD13M1 13 in. TV/DVD Combo Logo
202 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
