Question about D-Link RangeBooster G DPR-1260 (DPR1260) Print Server
I have a Toshiba e-Studio 166 with DPR-2000 and i have the same problem. It shows the printer offline in windows and device web console but the transfer rate is 480 Mbps in console Would you please help me? How can i install the Driver for the device into computers? The driver needs directly connection to install.
  • 19 Answers
SOURCE: DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Posted on Jan 12, 2008
sandeep239
  • 59 Answers
SOURCE: Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Posted on Oct 16, 2008
SOURCE: dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Posted on Aug 19, 2009
SOURCE: D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Posted on Feb 01, 2010
SOURCE: I recently loaded windows 7 and now I cannot print
Start > Devices & Printers > Add a Printer > Add a network, wireless or Bluetooth printer
> The printer I want isn't listed (unless it is!) > Add a printer using a TCP/IP address or hostname
> Device Type = Autodetect / Hostname or IP address: 192.168.XXX.XXX (The 1260's IP assigned by
your router - make it a static IP beforehand) / Port name: [the autofill IP is fine] > Additional port
information required = Standard "Network Print Server (2 ports - USB)" > Select the driver for the printer
you want to use...
Once the install is complete go to the Devices and Printers screen and click on the new printer.
Click Customize your Printer, change the name if you prefer and then on the ports tab. Mine is
set to Protocol "Raw", Port Number 9100, Community Name "public". The only other thing I may be
doing differently is that I have set the printer to auto-show the print preview before printing.
Yes, its an additional click but it seemed to have made all the difference in my case. It also
gives you the chance to correct something like printing a second page with just a header URL, etc.
I realize that time is a luxury and not everyone has a lot of it, especially for trivial tasks
like addressing antiquated equipment compatibility issues after an upgrade, but I firmly believe
if you say can't enough, you WON'T. But for those who enjoy a challenge occasionally I hope this
points you in the right direction. Good luck
Posted on May 12, 2010
Toshiba E-studio 181 it shows offline in computer.?
Check the properties after installing the drivers in the printer. You can select to enable or online the printer ..
Sep 13, 2014 | Toshiba E-Studio 181 Copier
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
We require a driver of e-studio 166 for windows 7 OS.
Toshiba e-Studio 166 is compatible with Windows 7 and drivers are available Toshiba Official Support
Visit the above link
Click 'Support & Drivers'
Choose B/W Copiers
Choose e-Studio 166
Select the complete drivers
and download the zip file.
Direct Download Link
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 22, 2011 | Toshiba e-STUDIO166 Printer
I want to install toshiba e studio 166 printer but I don't have driver so please assist me how can i install on xp os.
Toshiba e-Studio 166 drivers are available Toshiba Official Support
Choose B/W Copiers
Choose e-Studio 166
Select /
download the Full Installer
Direct Link for drivers download
CreativeTECH
Jul 06, 2011 | Toshiba e-STUDIO166 Printer
I want toshiba e-studio 206 driver for win 7 64-bit or any working solution
Toshiba e-studio 166/206 drivers are available Toshiba Official Support
Choose B/W Copiers
Choose e-Studio 166 (NOT 206)
Select the Complete drivers and download/ Install the required Drivers(
This package supports Windows 2000, XP, Server 2003, Vista, Server 2008, Windows 7 in 32 and 64 installations.)
You may also refer to the product manual
CreativeTECH
Jun 15, 2011 | Office Equipment & Supplies
I need drivers for my e-studio 166 for windows7
Here's the link for your toshiba e-studio 166 printer http://www.copiers.toshiba.com/support/downloads.jsp?SELCTD_MODEL=e-STUDIO166&AXN=SELCTD
It supports Windows 7 32 and 64 bit.
"This package supports Windows 2000, XP, Server 2003, Vista, Server 2008, Windows 7 in 32 and 64 installations. "
Happy installation.
Keep me posted.
Jas
Feb 18, 2011 | Toshiba e-STUDIO166 Printer
Hello i need to windows 7 driver for estudio 166 toshiba please help me best regards A.B.M. Kayes
Choose B/W Copiers
Choose e-Studio 166
Don't forget to convey your feedback
CreativeTECH
Jan 15, 2011 | Toshiba e-STUDIO166 Printer
I have Purchased Estudio 166 toshisha Printer/Scaner/Fax And Have a Driver Cd Pakagage but compatible with windows Xp/Vista but the issue computer runs on Windows 7 therefore I cannot print nor Scan
Choose B/W Copiers
Choose e-Studio 166
Select the complete drivers, which are compatible with Windows 7
Good Luck!
Appreciate generously if the solution could have been of any help!
CreativeTECH
Dec 22, 2010 | Toshiba e-Studio 282 Printer
D-Link RangeBooster G  DPR-1260 (DPR1260) Print Server Logo
353 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
