Question about HP LaserJet 4700 Printer
J'obtiens le code erreur 59.30 sur mon hp cp4005m. que dois-je faire?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 133 Answers
3 Suggested Answers
SOURCE: BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Posted on Jun 13, 2009
  • 100 Answers
SOURCE: plus moyen d'imprimer a partir
@claudezevart - C'est trop longtemps que je parle ou ecrire en francais, alors ma response en anglais...
My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Posted on Dec 28, 2010
Message d'erreur oooofeoo comment l'enlever faut il changer la batterie
Vous pouvez essayer de le réinitialiser en appuyant sur tous les boutons sauf le pouvoir et les boutons directionnels alors qu'il est allumé. Cependant, ce n'est que temporaire. Plus que probable que vous devrez faire réparer. Le code 0000FE00 signifie qu'il a du mal à communiquer avec la puce NAND. Si tel est le cas, la puce NAND pourrait être absent, il peut être rompu trace, ou votre CLK a court-circuité, donc changer la batterie peut ne pas suffire. Mais si vous voulez remplacer la batterie, suivez les 2 images ci-dessous. Je m'excuse d'avance pour toute erreur de traduction, que je suis américain et mon français n'est pas très bonne.
g6dlrvzpjeebldqs.mediumd2suhqut3ynfs5sm.medium
Mar 07, 2011 | Nintendo DSi XL Burgundy
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
J'ai par erreur désinstallé mon scanner
Commence par deleter Director Player . Va ensuite sur Device manager ( gestionnaire des p?riph?riques ) et delete ( pas seulement d?sinstaller ) le pilote du scanner .
D?connecte le scanner . Va dans le Control pannel ( panneau de configuration \ programmes ) et delete le logiciel de ton scanner . Fais un restart .
Ne connecte pas encore le scanner . R?installe le logiciel pilote . Fais un restart . Attends que le systeme d' exploitation soit compl?tement stabilis? .Reconnecte le scanner et attends confirmation que le pilote est correctement install? . Cela devrait marcher ? pr?sent .
Si oui , r?installe Director Player et vois ce qui se passe .
Dec 13, 2010 | HP ScanJet 2300C Flatbed Scanner
Bonjour, quand je vais sur internet et que je dois accéder au disqu dur, je ne peux plus rien faire. "ne repond pas " s'affiche. que faire ?
Windows a ete corrompu par virii - il est trop tard pour le desinfecter. Tu dois reinstaller Windows Tout de suite.
Nov 24, 2010 | Packard Bell Computers & Internet
Mon appareil canon ne marche plus!
Salut
Desole, mais mon francais est tres mal... Votre objectif a été endommagé dans la baisse et doit être réparé ou remplacé.
J'espere que ceci aide.
Thomas
Sep 19, 2008 | Canon PowerShot A550 Digital Camera
Probl?me de router
Si vous disposez déjà d'un mot de passe et quelqu'un d'autre est connecté, la seule chose à faire est de désactiver le sans fil.
l'autre personne est hautement qualifiés sur les ordinateurs.
Se connecter via un câble Ethernet.
Ou vous pourriez augmenter la sécurité. Dans les options, changer "WEP" à "WPA" ou "WPA2".
Aug 07, 2008 | Computers & Internet
La batterie faible
le problem est avec la battery, tu dois la changer.
Mar 06, 2008 | RCA Lyra RD2762 MP3 Player
Technics sd-s2300 ampli su-g91
tu dois voire si tu as tout les cables entre sur le stereo
Feb 18, 2008 | Technics SA-AX540 Receiver
HP LaserJet 4700 Printer Logo
337 people viewed this question
Seeker5211
Seeker5211
