Question about Tally T2250 Matrix Printer
Is there any spacific printer for cheque printing
That's not correct if the cheque has MICR encoding. You need a special printer for that.
Posted on Feb 27, 2013
I have a lipi pb2b passbook printer. now its some tools r not found. where i will be get its head and ribbon gear???????
Posted on Sep 07, 2010
  • 15,935 Answers
No - you can print with any printer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 06, 2010
Can't print payroll checks for intuit, get support code 2101 message
Is the paycheck form the same size as the plain paper? If not adjust the paper guides (and size selector if there is one) to the edges of the cheque form.
Aug 14, 2014 | Office Equipment & Supplies
Fault: misaligned cheque prints after 20 pages
If it gets off by a full line you have a problem in you print job. If not I've seen the tractors and spline shaft cause this issue.
Oct 31, 2013 | Printronix P7220 Matrix Printer
Do i need special ink to print my checks so they can be read
Are you trying to print from Quickbook ? There is no special ink required, you can print on your cheque's with regular ink in the printer.
Regards,
Sean
Jan 31, 2013 | HP Deskjet F4580 All-in-one Multifunction...
I'm trying to print the item description on my simply accounting cheque. It prints on the stub but not the actual cheque.
Check this out http://printerinkquestions.printcountry.com/category/Printer%20Settings-12.htm. There will be advance setting that you can set as you print.
"Please Post back to let us know if we helped "
Kindly rate this article.
Hope this helps :)
Mar 15, 2011 | Computers & Internet
I'm using tally 7.2, while printing cheque font size is very small how i can increase the font size? kindly help.
to increase the font size in the printing cheque is just simple go on to (or) press F!! key on the cheque printing option will available on there on the give yes . and then some kind of list will available on there on the list read the sentence one by one the font increasing size is available on there give the correct font size as a number for example (60)
Jan 21, 2010 | Tally T6218 Matrix Printer
I did a front feed on my Brother HL-1230 printer and now the cheque is jammed in the printer. How do I get to the drum to remove the cheque?
Open the front of the printer via the 2 tabs on the sides of the front door. Lift the toner/drum assembly out of the printer. You should be able to see the paper in the unit. Carefully pull the paper out of the unit. You may want to run a few pages through the printer to pick up any residual toner before printing another document.
Jul 16, 2009 | Brother HL 1230 Laser Printer
Printer manual
I need a printer Manual for Docucolour 12 from XEROX
Jul 04, 2008 | Office Equipment & Supplies
Sugest my problem
Will printing 4 lables and then will skip 4 lines and then print again
Mar 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Check printing
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Tally T2250 Matrix Printer Logo
426 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
