Question about Akai Mpc2500 Music Production Center
My mpc 2500 always stucks on start screen. the factory reset doesn't work, i even tried to turn it on without the exm ram card but nothing. i installed a corrupted jj os version so i only have to reinstall an os but how if the mpc won't start or reset at all?
  • Akai Master
  • 5,603 Answers
If you flashed a bad OS, the unit MAY have to go to the factory to be reloaded.
Go to VSPlanet.com and see if someone there might be able to help.
Posted on Sep 06, 2010
Hi As recently as a month ago I bought a Kurzweil PC3K8 from sound solutions. On 13/08/2011 I took the keyboard (in a flight case) to a gig. After setting up the keyboard and powering on, the blue light...
Hopefully you didn't take it on a flight as sometimes they use bomb detecting equipment that subjects cargo to either high levels of radiation or high electro-magnetic fields. This can damage the equipment. It sounds like the processor is not running. There usually is a screen contrast control that can be turned enough that the screen appears blank, but usually you can get a sound out of the unit without reading the screen, Look in your user manual for a FACTORY reset or restore and pperform that procedure. If that doesn't work, then repair is in order. If unit has been vibraated during transportation, it is possible a cable has come off inside. Since you just bought this, EXERCISE you warranty immediately.
Aug 14, 2011 | Kurzweil PC3K8 88 Note Performance...
When i go to format my cf card in the mpc, the mpc does not allow the do it button to be pressed. when i press it nothing happens it does not even blink red.
Check that your CF card is NOT biggerr than the unit allows... read the specs. A lot of equipment is having trouble with the larger memory cards. Unfortunately the smaller ones are almost non-existent.
May 02, 2011 | Akai Mpc500 Mpc 500 Drum Sampler,cf...
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Aug 20, 2010 | Akai Mpc2500 Music Production Center
I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH MY AKAI MPC 1000, PARTICULARLY HOW TO SET UP THE MIDI ON THE ROLAND.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Aug 16, 2010 | Roland Juno-D
When I have my instrument cables coming out of the stereo outs of my mpc 2500 but it out come out mono. I don't know how to make it come out stereo. Is my mpc 2500 broke
To get stereo you must record in stereo or "PAN" individual inputs to one side or the other to create seperation. Your device is NOT broke.
Read your manual about panning.
Aug 04, 2010 | Akai Mpc2500 Music Production Center
Os update promblems mpc 2500
Try this site:http://www.akaipro.com/mpc2500 Try downloading all the the release notes for ver.1.24 if you haven't already. Download the ver.1.24 which seems to be the newest to your computer first and install from there. It might have gotten corrupted the first time you tried it. You will have to email them using the form for the newest release notes and the installation instructions:http://www.akaipro.com/mpc2500 http://www.akaipro.com/content1924.html and http://www.akaipro.com/mpc2500 are the URLs you need. Hope this helps.
Apr 16, 2010 | Akai Mpc2500 Music Production Center
Akai MPC 1000 is stuck in USB mode
I'm having the same problem. This is my second MPC 1000 and my first one didn't have this problem. I bought one of the first one-thousand MPC 1000's sold in the US. I loved it. I sold it for rent, boo hoo. I'm glad to have another one back in my life. But sad to see it having issues already. I've only had it for a week. I have emailed Akai regarding this issue. I'll post pack here if they give me a good fix.
Mar 25, 2010 | Akai Mpc1000 Sampling Music Production...
Akai Mpc2500 Music Production Center Logo
831 people viewed this question
Top Akai Music Experts
Michial Gueffroy
T-Comtech Repairs
T-Comtech Repairs
Are you an Akai Music Expert? Answer questions, earn points and help others
