Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Sony projection television KP51HW40/ bought in 2002 .
The television shut off by itself and won't turn back on. The error code is 8 flashes repeated. When the power button is pushed to on, the screen turns blue,there are ghost images on the screen for only a few seconds then the unit shuts off. Any help will be very much appreciated.
  • 1 more comment
  • c-murda Jun 15, 2008
    My tv does the same thing. It will flash blue and shut off then flash 8 times on the led light. is this repairable for a decent price?
  • Anonymous Jun 17, 2008
    tv code 8 flashes
  • christ89 Sep 30, 2008
    same exact problem with mine. ANy idea of costs? Can I do it myself?
Had a repair man come out to fix it and it turned out to be a bad projector and another one going out. He showed me by hitting the tubes and they both would flash. The third one was ok. i gave him the good one and he waived his service charge. i went out and bought a 61 inch samsung dlp. he said it would be 900 to replace one tube because of labor. he said he could only get the tube but not the rest surrounding the original tube. so he would have to remove all the old stuff from the old one and install it on the new one. cheaper to buy a new tv.
Posted on Nov 20, 2008
  • Sony Master
  • 8,617 Answers
The flyback is bad when you get 8 blinks on the diagnostic led error code. If you need more assistance let me know
Posted on May 13, 2008
Red out of place on a sony kp51hw40
red and green lights repeat but tv not start
Sep 29, 2012 | Sony KP-51HW40 51" Rear Projection...
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
MY TV DOES NOT TURN ON AND I HAVE A BLINKING RED LIGHT MODEL IS KP51HW40
the blinking red light is an error code. How many times is it blinking and I will let you know what the error is indicating?
Aug 22, 2011 | Sony KP-51HW40 51" Rear Projection...
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
2002 sony #kp51hw40 flashes red light and then shuts off
Count the flashes and the gap between the flashes as I know from experience the tv is giving you an error code in this way to say what is wrong. You should even be able to do this while the tv is in standby. Then once you have the code either consult your manual or try some of the sony forums to find out what the exact problem is. Hope this helps.
Sep 30, 2008 | Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
