Question about HP DesignJet 130 InkJet Printer
How & where do I install the paper cutter on HP 130
    Brigadier General:
  • 3,917 Answers
Hi
The cutter attaches to the aluminium track you can see when you look into the front of the printer.Its a little plastic part which houses a round knife and it sits over on the left side while you're printing. Then when it's time to cut, the printer head travels over,
grabs the cutter, and drags it over to the right side, cutting the paper in the process. Then the printer head and cutter travel back to the left and the cutter is left parked there until it's needed again.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 06, 2010
HP DesignJet 110 - will not move cutter after job is printed
for paper cut, you should see the printer properties, there you can fine Auto Cut paper Check box or some thing like that. Make the correct setting, then it will work.
Thanks & Good Luck
Iqbal
Jun 10, 2008 | HP Designjet 110plus nr InkJet Printer
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
The paper cutter on the Designjet 130nr jams all the time. Help? Where are the screws for the cutter?
from memory this cutter is removed by removing the side cover and sliding it off the end of the carriage rail.
Aug 15, 2011 | HP DesignJet 130NR InkJet Printer
Trying to print a 4 x 6 photo with HP Photosmart 130 I'm trying to print a 4 x 6 photo with HP Photosmart 130 printer, from my desktop HP Photo & Imaging software. It prints all but last 1/2...
It is for sure a matter of settings ..so you have to select the paper type ..and the dimensions ..and also the position ...landscape or portrait ...and after that go for the print..Also select the paper type and size in the printer if it has the feature for it ...It is safer to select there too ..cause from computer you have to make it each time and you may miss something ..
If it is still making problems ..just reinstall the printer 's driver and software from scratch ./..(remove the old one ..and reinstall a clean version of the software ) This way you will be sure it is not an software error..
Aug 02, 2011 | HP PhotoSmart 130 InkJet Printer
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
Panasonic fax
If there is a cutter it might be defective,try to off the cutter.If the is no cutter check paper sensor.clean or replace it
Mar 06, 2009 | HP FAX 1250 Fax Machine (Black)
Photosmart 130
Mine just had this error and I fixed it by cleaning the big front black roller and the small Grey rollers in the back with q-tips and rubbing alcohol
Jan 11, 2009 | HP PhotoSmart 130 InkJet Printer
HP DesignJet 130 InkJet Printer Logo
751 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
