Question about Samsung Computers & Internet
I have a samsung flat monitor which is in use for 5 years. Recently it is taking a long time to light up even after the pc has become active.
  • 11,361 Answers
Flat pabel LCD type monitor, if that is the case, more likely the DC filter caps will be bad by now.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 07, 2010
I have a Samsung Syncmaster 710M that's about 5 years old. It had been lying around in its box for more than a year. When I tried to use it recently it shows the "Check Cable Signal" screen...
when you connect your lcd with computer and when you put on your computer after that press the source button on your lcd, then it will bring the display in front of you dear. thx
Jun 24, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
When i start my computer up my samsung 732n monitor comes on, for i see the initial boot info but then it goes black. even tho the blue light button is on.. i have to press the power button, onthe monitor,...
i think this not from yor monitor, but from your PC, is your PC ok???not infected by virus??try uses another monitor, if there still like that it means your pc infected by virus, reinstall your pc
Dec 05, 2010 | Samsung 732N 17" Monitor
Mac sound problems
so if your fans are over exerting themselves, your mac is working to hard..
open your activity monitor Applications/Utilities/Activity Monitor, and look at what is working so hard...Can take it from there if you post your results..
Jun 08, 2010 | Apple 3-Year AppleCare for iBook/MacBook...
Recently the font on my monitor has become a bit fuzzy, I've tried auto adjust, changing the resolution but they did not help. My motherboard and video card were recently replaced but the person who...
the refresh rate frequency should be 60hz, and monitor resolution 1024 x 768 , should work fine but if the the problem still it might be the lcd monitor getting OLD :) ,you can make sure by connecting the monitor to a different pc and notice the font.
Feb 26, 2010 | Rosewill R700J 17" Flat Panel LCD Monitor
I have a mac mini osx10.4 with a 512N syncmaster samsung monitor. The monitor worked fine for 2 years and up till the last month while I am on the computer the monitor will go black with a message saying...
samabbott, Toni, The very first thing to check is Samsung warranty.. If not valid you will need to check and see if Samsung has a cash+old unit swapout program for refurbished same model??? Will this 512N do same thing if connected to different pc? If so, then I would suspect the unit's power supply. Whenever strange or weird stuff starts to randomly take place with an LCD display, I would first check the "switch-mode-power-supply"! Have you tested the pc with different Known Good lcd unit? Try the above stuff and report back with a new comment. 12fixlouie
Nov 17, 2009 | Samsung SyncMaster 512N 15" Flat Panel LCD...
A black flickering line about 5" from the bottom on my samsung syncmaster 793s 17" CRT Monitor
Hi rkarthea,
Well to narrow down the problem I would suggest first that you try to disconnect the monitor from your APC Back-UPS and just plug it directly to the wall outlet, UPS or surge protectors may cause interference at times with some electronic devices. Then if it's still here, I would recommend that you try to degauss the monitor, all CRT monitors have this option in the OSD. You should also check if there is any magnetic device near the monitor, like a speaker or phone that can cause this. If another PC is available can you try it there also, see if the problem is seen on another PC.
Finally, run the monitor self-test, to do this just leave the monitor plugged into the power outlet and disconnet the video cable, and you'll see it. If the problem is still there then most likely the monitor will have to be checked in a service center or be replaced eventually, since this would already be a hardware problem. Especially since you said the problem is apparent even in the OSD.
Hope this helps!
Peace! :)
Oct 23, 2008 | Samsung 793S 17" CRT Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Computers & Internet Logo
643 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
