Question about Honeywell Heating & Cooling
Hi, we have a Honeywell ducted heating thermostat model t8602c2069. It has recently stopped working. This display panel is working so it's not the batteries, however when we turn it on heat does not come out of the vents. We recently had our safety switch turn our power off whist the heater was on. Since then we think it has stopped working. Our power has gone off several times again after this so we do not beleive the heater caused the safety switch to turn our power off. The only difference on the display since then that we have noticed is that there is a square symbol (not flashing) appearing on the display in the middle at the bottom of the screen. Can not work out what that means?
We have exactly the same problem as dmlauder! (posted 6th September)
What does the square symbol mean?? We have to keep resetting the outdoor heating unit...it works for a few minutes then stops
cate
Posted on Sep 10, 2010
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
The emergency heat will not turn on in my system. I also noticed the emergency heat light does not turn illuminate on the Honeywell HZ322 TrueZone Panel even if the emergency heat button is pressed. The...
Yes, I believe you are correct concerning the circuit panel.
Regarding your heat pump not keeping up ...depending on what part of the country you live in, heat pumps are not the best thing to heat with. As you probably already know, once it reaches 32 degrees outside, the heat pump stops working and the electric furnace or heat strips come on to supply warm air. Frankly, when that happens, it's like turning on your kitchen toaster and blowing air across it with an electric fan. Doesn't sound to efficient does it. Plus, your electric meter is spinning like crazy and the power company is falling in love with you.
In my area (Virginia) most new home construction is now using what's called a dual fuel system. It's a heat pump, but it has a gas furnace backup for when it reaches 35 degrees outdoors. It's very, very efficient and a very comfortable heat. The gas furnace can run on either Natural Gas or Propane Gas.
In most cases this can be added to an existing heat pump system. The only thing necessary is the Gas Furnace, since you already have a heat pump and all the duct work. Could probably be added for a whole lot less than you''d expect.
The other option is to add a vent-free gas fireplace or vent-free gas logs, if you have an existing solid fuel burning fireplace. They are great for zone heating and/or supplemental heating. Plus, if you have a power outage in the middle of the winter, they'll still work, as they don't require any electricity.
I didn't mean to run own, but I hope all this helps you solve your heating problem.
Please let me know.
Rich
Feb 09, 2011 | Amana PTH123B25AJ Heat Pump Air...
Banging noise when motor turns off
Have you replaced your air filter recently? Often this is a symptom of a restricted return. The blower almost causes a vacuum in the duct work, and when the system shuts down the duct "pop" back out, causing this banging noise. Hope this helps
Feb 05, 2010 | Honeywell Electronic Programmable...
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Brivis Ducted Heater works Non-stop
When you disconnected the W wire, was the R wire hooked up? If so then you either have a bad tstat or the R and W wires are shorted together.
Jul 23, 2009 | Honeywell Heating & Cooling
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
341 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
