Question about Cat5e 100' Network Cable (CAT5100)
Can we use kvsf 75 instead of cat5e cable - Cat5e 100' Network Cable (CAT5100)
I have a as sc15a camera and I need to know how to wire it to RCA cables instead of the CAT5 that is coming out of the camera I do not have an adapter or a transceiver please help it is a 6 wire coming out...
Ok Red and black are for 12V DC to power the camera then yellow and white can be for video signal or if black is common negative then Yellow and Black for video signal.to a monitor screen .
Feb 06, 2018 | RCA Computers & Internet
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Is it possible to have 2 pieces routers to expand the distribution of internet connection instead of using router to hub? what type of cabling should i used to do it? please help thanks
I guess you have a single incoming internet connection and wish it to be shared.
You only require one DSL / Cable router. To share this connectivity you will need Ethernet / Cat5 or wireless.
An ethernet switch or hub will enable you to extend connectivity.
All cable should be CAT5e or CAT6.
Suggest you consider the slightly more expensive switches that have auto-uplink. The negates the need of crossover cables.
Regards B.
Mar 21, 2009 | 3Com Computers & Internet
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
I want to connect my monitor which has a vga connection via a cat5e cable to my security camera which has a bnc connection on it
With the indulgence of IB4G2008...
Not possible without a converter adapter at the same time signal losses, interference and noisy video if CAT5E cable used.
What I would suggest is to use coaxial cable (RG59) instead of the CAT5E. One end would be terminated with ta BNC male to connect to the camera. The other end would have to be terminated either with an RCA male. Before connecting to the VGA (15pin) input of the monitor, it would have to be processed by a converter/adapter. Here are some examples:
1. Composite Video to VGA adapter;
2. some high end adapters are shown here;
3. several shown here would also work.
In case you would like a DIY, this might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 29, 2008 | Computers & Internet
How to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
http://www.serverracksandcable.com/cat5-cat5E-cat6-cat6A-cables-limitations.php
Mar 07, 2008 | Computers & Internet
Internet connection for 360 elite
You can purchase as much ethernet cable as you need. You can purchase pre-made ethernet (cat5e) cable at circuit city, best buy, compusa etc. for not too much money. They usually sell in up to 50 or 100 foot rolls, if thats how much you'll need. If you're going over 100 feet I'd suggest going with cat6 cable, instead of cat5 because it can handle longer distances better.
Jan 08, 2008 | Microsoft Xbox 360 Console
Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Nov 04, 2007 | Cat5e Cat 5E Modular Plugs - For Round...
Cat5e 100' Network Cable (CAT5100) Logo
42 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
