Canon GP405 how to replace waste toner container?
  • slinkybeachb Sep 06, 2010
    It's a COPY MACHINE not a fax machine!
  • 619 Answers
SOURCE: waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
Posted on Jan 10, 2008
  • 168 Answers
SOURCE: Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Posted on Jan 03, 2009
Cogz
  • 1326 Answers
SOURCE: a message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Posted on Apr 15, 2009
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
  • 6 Answers
SOURCE: Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Posted on Jun 02, 2009
Where is the waste toner container on a canon 7065 copier fax machine
waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
How do i replace the waste toner container on a Canon Imagerunner 4570?
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge.
If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
Feb 02, 2010 | Canon imageRUNNER 4570 Copier
E019 CODE ON 6085 CANON
E019As many as 50,000 have been made after detecting a waste toner full condition.Extract the block of the scene and free the container with perfected by toner. Good luck
Sep 20, 2009 | Canon NP 6085 Copier
Canon Imagerunner C3100
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Displayed error
sol:
1:you have to replace the drum unit.
or
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
Jan 13, 2009 | Canon imageRUNNER 400S Copier
Jan 02, 2009 | Canon imageRUNNER 5020i Copier
Error message E1 CHG.WST.T.CTN on Canon LBP5960 printer
<E1 CHG.WST.T.CTN> Cause:
The waste toner container is full.
Remedy:
Replace the waste toner container with a new one. as per
http://support-hk.canon-asia.com/contents/HK/EN/8000559101.html
Sep 30, 2008 | Office Equipment & Supplies
Waste toner container on canon imagerunner 330s
www.justmanuals.com
Jan 10, 2008 | Baby Gear
47 people viewed this question
k24674
