Where i must go to enable the sata from bios? on p5rd1-vm?
  • 57 Answers
If your motherbord has sata no need to enable anything or buy yourself a convetor form IDE sata
Posted on Sep 06, 2010
I want to install xp sp2 on Sata HDD The motherboard is P5RD1-VM but there is error set up did not find any hard drive plz tell me settings of bios to sata compataibale
It's likely a problem with your connection cable from the HDD to the motherboard. The bios shouldn't have to be set up for the HDD to be recognized through a sata port.
Jul 17, 2011 | ASUS P5RD1-VM Motherboard
How to install windows xp in p5rd1-vm? when installing windows xp it goes no hard disk found. cant find sata hard disk. please help me about this problem.... thanks!
Make sure all the connectors are plugged in and in the correct spots. Then go to the bios and enable the SATA drives to be read. After that you should be able to boot from CD and install XP.
Jun 16, 2010 | ASUS P5RD1-VM Motherboard
P5rd1-vm sata installed xp nit detect
Check in the BIOS settings. You probably want to either enable legacy AHCI support, or you need the appropriate AHCI/SATA drivers for Windows XP. Otherwise, the system will install in compatibility mode, and then be unable to recognize the disk once booting in standard mode.
http://en.wikipedia.org/wiki/Advanced_Host_Controller_Interface
Also, verify that you have the latest BIOS installed:
http://support.asus.com/download/download.aspx?modelname=P5RD1-VM&SLanguage=en-us
Oct 27, 2009 | Intel ASUS P5RD1-VM ATI Radeon Xpress 200...
I can't use any sata hardwewr on my motherboard
create a sata diskett[floppy] using your motherboard cd and press F6 when booting from xp cd this will install sata raid drivers for your motherboard
Jun 23, 2009 | ASUS P5RD1-VM Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
Raid controller disabled to P5RD1-VM
The manual is here: http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf (very slow download). Look under Advanced/Southbridge/SATA
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
