Question about HP LaserJet 2840 All-In-One Printer
I had a problem in the printer saying that 50.2 fuser error that i can neither print, nor xerox & nor scan also. what can i do now?
    Sniper:
  • 56 Answers
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Posted on Sep 08, 2010
What does error n9 indicate?
You may call on 877-372-5594 (Toll Free) for help.
Dec 03, 2015 | Xerox WorkCentre 5020 Laser Multifunction...
A want to make my printer work it is showing a message (printer fuser temp, will you help me to solve the problem
That error indicates that your fuser is not getting hot enough to fuse the toner to the paper. If you can get to it then make sure all the cable leading to the fuser are hooked up well. If they are and nothing has wiggled loose then the fuser is likely faulty and needs to be replaced.
Sep 20, 2014 | Xerox Phaser 3100MFP
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Xerox 6600dn can it scan slides
If you mean can the printer print onto film slide to display on an overhead projector then I'm almost sure it can, however ensure the slides are of reputable quality i.e. Xerox slide material because the material will fuse and stick inside the fuser causing an expensive mess to rectify.
Good Luck.
Mar 20, 2014 | Xerox Corporation Phaser 6600DN Laser...
Xerox 6350 prints to much magenta
is it also when you print blank pages after the 25-50 pages? if so it could be the fuser, if not it could be the imaging unit. Check your magenta imaging unit and fuser roller anyway. If any of them is dirty, replace them.
Dec 02, 2013 | Xerox Phaser 6350/YDT Laser Printer
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
THERE IS A DISPLAY ON XEROX PE220 THAT OPEN HEAT ERROR & THERE IS NO PRINTING
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 05, 2010 | Xerox PE120i Laser Printer
Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
HP LaserJet 2840 All-In-One Printer Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
