Question about Ricoh Aficio CL7200 Laser Printer
The colour settings are not right on my Ricoh Cl7100. What are the optimum settings for density and colour calibration settings.
  • 903 Answers
On the CL7100, you can run the color calibration procedure, and the machine should set itself up for optimum color. Just go into the menu, and under the Maintenance heading choose Color Calibration.
Is the color still off after running the calibration? Is it only one specific color, or all colors? What about when you only print black & white?
The image density should typically be left at the default values for optimum print quality. However, if you need to adjust it, you can go from -3 to 3. In the menu, go to the Maintenance category and then choose Image Density and then the color that you want to change. Adjust the value and press Enter, then run a test copy to see if it helps at all. If not, reset it back to the value that it was (probably 0).
If only one color is giving you a problem, even after running the color calibration, you might need to replace the developer unit for that color.
Posted on Sep 06, 2010
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
Apr 27, 2015 | Ricoh Aficio CL7100 Printer
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
number of sheets setting".
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
Apr 12, 2010 | Ricoh Aficio CL7200 Laser Printer
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
How to get borderless printing on a CL7100
Laser printers are unable to print all the way to the edges of the paper because of the excess toner dust that will fall off into the printer unit. The only way to get true full bleed laser prints is to use a larger paper size and then cut the edges off.
Jun 17, 2009 | Ricoh Aficio CL7100 Printer
Printing red stripe
Replace the magenta photoconductor.
Mar 09, 2009 | Ricoh Aficio CL7100 Printer
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
HP Color Laserjet 3500 Problem
If you are sure the diagnostics show the colours correctly, one thing I would look at is to see if it had a colour profile set up for it.Don't know whether this printer normally has, if it has not I would suggest reinstalling the driver. To check - Start/Printers & Faxes/ Rt click on printer then properties, look under Colour management tab. Pete
May 25, 2006 | HP Color LaserJet 3500 Printer
Ricoh Aficio CL7200 Laser Printer Logo
210 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
