What does SP mean on my Westinghouse 8KG washing machine {LT8195} this error code keeps coming up and I don't have a manual
  • 183 Answers
SOURCE: zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
  • 74 Answers
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Posted on Apr 04, 2008
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
Posted on Jun 23, 2008
Elextrolux EWF168540 W TimeManager 8kg stopping mid program without any error message
The recurrent problem may be due to a defect in the Time Manager.
Feb 01, 2017 | Washing Machines
I have a Westinghouse LT8195 washing machine,error code is coming up SP ? Do know what this is ? Please help
I think you may have used the wrong kind of detergent or too much.your washer is most likely over SUDs.If you don't use he High Efficiency detergent this will happen. There is a he swirl on the container.shut down you washer for a half hour let it settle. Clear the drain as best you can from suds. if your model has a no spin or low spin use your rinse cycle.you may have to do this again if suds are to thick. Westinghouse has an SD code for SUDs. If you have an owner manual check it.continue to wash normally
Jul 27, 2015 | Westinghouse Washing Machines
Last month my aquasmart had fault code 130 payed repairman $180 to fix it now it has fault code 105 your webpage is very unhelpful knowing whats wrong with my aquasmart which is less than 5 years old
Did you look up your manual to help with the problem?
AquaSmart2 8kg - this is a link to download your manual
The good thing is that if you got Fisher & Paykel to come out, they offer a warranty on their service - so call them again and tell them the situation - they should come out for free....
Sep 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
What does the fault code E18 mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
Error h51 panasonic front loader washing machine 8kg
What happen the washing machine model NA-148VG3 show H57 mean what happen?
Jun 02, 2013 | Washing Machines
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
May 15, 2011 | Fisher and Paykel Washing Machines
My westinghouse washing machine LT809s keeps beeping at me and displaying the error code LL?
It means Low Level. Your water level is too low. Your machine isnt filling up properly or the water is being siphoned out as it fills which means your drain is lower than your water level. or your drain does not have an air lock in it any more.
Mar 31, 2011 | Washing Machines
I have a stirling washing machine xqb90-701clps and the machine has come up with an E4 error code.. cannot find my manual. what does that code mean?
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
Jul 25, 2010 | Washing Machines
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
