Question about Kenwood KVT-817DVD DVD/CD/MP3/WMA 7" Motorized In-dash Monitor With 5.1ch DSP Car Video Player
CD/DVD only works in Dual Zone?!
I have had my KVT 817DVD in for about 3 months now and I love every second of it. Hooked it up to some great speakers and they sound great on Sirius. The only problem is that I can only listen to CDs through Dual Zone, and in Dual Zone, I find that the equalizers cannot be changed. HELP!
  • 47 Answers
CHECK YOUR CONNECTIONS FROM HEAD UNIT TO BRAIN THERE IS A SMALL GREEN PLUG MAKE SURE IS CONNECTED
Posted on May 13, 2008
  • tooloney4u Apr 06, 2011
    Hello had the same problem... i found that it was my wire harness going from the brain to the speakers the connectors at the base of the wire harness where loose so i just soldered them and that fixed it...hope this helps.
Does the 817 come with a brain?can i get the harness separate that has the speaker connections as well as the audio jacks
KVT-817dvd MANUAL LINK
Yes - there is a separate receiver unit.
CLICK HERE to see all the available parts to the unit.
Look at the installation part of the manual to determine which harnesses you will need.
Thanks!!
Feb 07, 2011 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Tip
Kenwood Excelon Manual (KVT-817DVD)
Kenwood Excelon KVT-817DVD Users Manual
Misplaced your Kenwood Excelon KVT-817DVD manual?
Would you like a pdf format, digital, searchable KVT-817DVD users guide?
The Kenwood Excelon KVT-817DVD owners guide is available here.
I hope that helps.
on Apr 02, 2010 | Car Audio & Video
Tip
Kenwood KVT-817DVD Manual
Kenwood KVT-817DVD Users Manual
I hope that helps.
Everything works fine when i play a cd it works it reads it but dont hear the music when i turn to radio i hear the music,just wondering what could be wrong help me out thanks..
sounds like you have it hooked to an amp and have the blue power antenna wire instead of the blue and white amp remote turn on connected the the amp remote turn on terminal.
Mar 04, 2010 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Kenwood KVT-817DVD screen goes black, have to reset constantly
Hello johnnychi925,
The unit appears to have been installed on the 12vdc connection that is on the same circuit as the the vehicle's ignition switch. This means that when the ignition is turned there is a rapid drop in voltage which cause the problem with your device. You need to connect the device to a 12vdc circuit that comes straight from the battery and does not connect to the ignition circuit. Now for another possible cause if the 12vdc you are connected to is from the battery and not the ignition connection. The battery could be dropping below 12vdc during the starting of your vehicle. This could be the sign of a malfunctioning battery, or a problem with the car's electrical system.
To test out if the battery ids dropping below 12vdc I would suggest connecting a voltmeter to the - and + of the battery and starting the car. The voltage should drop but not below 12vdc.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 12, 2009 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Tip
Kenwood KVT-817 Manual
I hope that helps.
on Apr 02, 2010 | Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car...
Missing Wiring Harness
Dear speizio, 02-09-2009 3:49 EST (USA)
Look in the phone book yellow pages for a small unknown Stereo Radio Dvd store near you.....these are many and you should have one nearby.. because kids love their music and installing the lastest equip...
They will have the wiring harness and can walk you through installation or do install for modest fee!
Feb 09, 2009 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Kenwood in-dash dvd player kvt817dvd cuts out
inside the unit there will be a small battery, this will need replacing as its not holding its charge, the battery is just like a watch battery, as soon as this is sorted it will work fine.
The battery is for holding system information like for instance the time and date, and all over things that you might have programed with it.
Hope this helps.
Please rate me
Thanks
Feb 19, 2009 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Kenwood kvt817dvd powers up after reset but cuts out after src
I removed my brain from beneath my seat and exposed all wires and connections. I have found that on mine (kvt-815) there were two pinched wires- 1 for a speaker and the other the remote wire. I respliced these sections and tested my radio again. It appears to be working now and stays on again. I'm guessing one of the wires must have been touching something metal under the seat (seat frame) and grounding out. If the unit doesn't power on at all, check the fuse first. Otherwise, I would  inspect every wire like I did and maybe you'll find a pinched (grounded) wire. Maybe I just got lucky... but at least it's working again and I don't have to replace the brain! Hope this helps.
Jan 05, 2009 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Kenwood KVT-817DVD DVD/CD/MP3/WMA 7" Motorized In-dash Monitor With 5.1ch DSP Car Video Player Logo
121 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
