Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant format or put data on my Verbatim Memory stick disk is write protected, and it appears the following pop-up screen Verbatim Memory stick disk is write protected so please provide me with the solution ASAP Best regards Alaa
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Sep 06, 2010
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2566734
Points
35672
Some Verbatims have a write protection switch on its side - make sure it's not activated. Then open the properties of the stick in My Computer. If in there the stick isn't set as read only then it has died - there's nothing more you can do to save it. Junk it and get a new one.
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
I can't open because of the paSSWORD IN IT.
Hope this helps.
1helpful
When ever i try to copy a file on to my pendrive ,a file pops up saying that it is a write protected drive .how am i to remove this write protection?
try this one, hope it will work on your memory stick coz i tried this and i was able to format my write protected memory stick smile.gif
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost, am pretty sure you know it
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
How can i format my hp USB memory stick?
try cleaning it anti virus.. i suggest mcafee 8.5i enterprose version is good one.....
or try the link
http://en.kioskea.net/telecharger/telecharger-127-hp-usb-disk-storage-format-tool
2answers
I used Windows to format 4gb memory stick PRODuo, now what?
your 4gb drive has definately a partition virus.
i recommend u to use net protector a virus removal software to tackle this problem
may be demo version will not remove the virus but clean any malware and inform you about the virus.no other software may help as this 4 gb has a partition virus and there is an unseen partition (hidden one) on the drive... which the net protector will delete.
datarecoveryfactory
Verbatim 8G USB memory storage stick not working
There could errors in the drive. You should either run a scandisk on it or format it altogether. Either should get it back up and running is it is a genuine device.
1. To check for errors/scandisk right click on the icon of the memory stick, select properties. Under the properties menu look for Error-checking and select check now. The check disk menu pops up. See that Automatically fix file system error box is checked. Then click on start.
2. If you decide to format the memory stick just right click on its icon and select format. But see that you move you vital files from it first else you will loose them.
1helpful
4answers
How can I recover my Verbatim Store 'n' Go Red 4G memory stick?
Hi Karen
Follow the link bellow i have used this a couple of times and it seems to work well
http://www.filehippo.com/download_recuva/
Regard Alan (alstech)
I bought a 1.0GB Scan disk and don't know how to format it...can you help?
maybe its write protected in that way you cant put any data or erase from it. its located from the side of your memory card.
formating your disk is as easy as selecting FORMAT DISK/MEMORY CARD
Oct 07, 2008 • Cameras
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
