Question about Acer Aspire 6920 Notebook PC
Hi i put my acer aspire 6920 through a restore to fatory settings, it restarted itself and now it starts up as fair as the logo and then all that happens is a flashing line in the left hand corner please help thank you
  • Acer Master
  • 11,800 Answers
The BIOS can't locate the boot loader so windows can't be booted. It's a bad install, do the recovery procedure again. If it fails again then the hard disk is defective, replace it before reinstalling one more time.
Posted on Sep 06, 2010
Acer Aspire 6920 Restarts in Normal mode and works only in safe mode
Sounds like the MBR ( boot files) are corrupted. Try formatting the hdd before you instal again. I'm sure you have a restore sector on the hdd in which case, if you have done anything to that then you'll need to have the restore disc set which usually comprises of the restore disc and the drivers disc. Either way....just make sure you format c and not d which is usually the resore partition. Good luck
Nov 24, 2013 | Acer Aspire 6920 Notebook PC
My acer 6920 restarts automatically when AC power pluged in.. it runs fine in safe mode and on battery too it runs fine..... what to do ?? service center says d mother board is causing problem but no...
Start your system in Safe mode.
and try to restore your system for previous date.
If your are not compatible with how to restore, Go to the link and follow the steps.
http://support.microsoft.com/kb/306084
Otherwise you can try to reinstall the OS.
Thanks for using FixYa.
May 17, 2011 | Acer Aspire 6920 Notebook PC
Hi i reset my acer aspire 6920 to factory settings as the system was running very slow and i could not find the problem...but now i have a worse one.... once it does the factory restore by pressing alt f10...
Sorry to hear about your problem.
The only other way to resolve this issue is going to with the use of recovery media.
Currently you're using the built in partition, but i'm hoping you also made some disks like it would've asked you to.
If so, insert disk 1 and restart to load from the recovery disc.
If not - you can contact Acer to be supplied with these, they'll still be a lot cheaper than buying Windows, but will cost approx $50.
Apr 26, 2011 | Acer Aspire 6920 Notebook PC
Acer aspire 6920 laptop some times automatic restart. in normal mode hang when connected ac adapter
It appears that some of the the Windows files are corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as
soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 24, 2010 | Computers & Internet
Reset acer aspire one d255
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.This will RESET the computer to its Factory Settings( DATA LOSS )
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Oct 21, 2010 | Acer Aspire 6920 Notebook PC
How do i put my laptop aspire 9300 back to factory settings
To Recover your system from within Windows
1. Click on Start, then All Programs, then Acer Empowering Technology.
2. Click on Acer eRecovery Management.
3. If prompted to create a password, create the password and hint
Do not lose this password.
If asked for a password, enter the previously set password.
4. When the Acer eRecovery Management loads click the button labeled Restore.
5. Click on Restore system to factory default.
6. The unit will restart and start the restore.
It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
7. At the eRecovery Management menu it will ask you how to restore.
Click on the restore option you would like to use.
To recover your system from bootup
1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
2. Power the system on.
3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
4. At the eRecovery Management menu it will ask you how to restore.
5. Click on the restore option you would like to use.
Jan 31, 2010 | Acer Aspire 9300-3716 Notebook
I am wanting to restore my laptop to factory setting
#1: Start up your computer and as the computer logo appears (such as Dell orHP) hit "Ctrl>F11" simultaneously. This may be different fordifferent machines, but the most common keys to hit are"Ctrl>F11." If this does not work, the F8 key has been said towork for certain machines.#2: Select "Repair My Computer" from the list of menu options thatappear and press "Enter."
Jan 04, 2010 | Acer Aspire 6920-6621 Notebook
I have an acer aspire 6920 laptop and i am trying to do a system restore but not have a disc, wat can i do
Reboot the system and on restart press the F8 key to access the advanced system options. Select repair my computer to start the system recovery partition.
This option will restore the system to factory settings and some files or programs will have to be reloaded.
I’m happy to help further over the phone at https://www.6ya.com/expert/walter_628d4d23d01fb34d
Oct 31, 2009 | Acer Aspire 6920-6422 Notebook
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Boot problem
restart and get into bios setup
then on the page usually at the bottom
restore to default settings then press f10 to save and exit.
if it still does'nt start PLEASE let me know we can try a new solution
do you know what you were doin last before this happened
Feb 01, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 Notebook PC Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
