Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
TV displays only two colors yellow and purple
My TV all of a sudden started displaying only 2 colors yellow and purple. Can someone tell me if they experience the same problem? I tried hooking up a DVD to different inlets and the same thing happened leading to beleive it's not only that inlet that is defective.
  • 558 Answers
You can only have the component video hooked into the component video if you try to down grade (used s video or the yellow cable to connect video you you will get funny colors you need to change the output of the dvd player to one of those not progressive scan on the component side. hpe this helps
Posted on May 28, 2008
Ok I have a pioneer stereo in my truck ,which someone else installed it before I bought it ,it's never held it's memory like time,presets or display setting , it will for only a few mins after truck is...
You have a red wire and a yellow wire,both of them are hot wires.ome is memory the other is constant hot.the yellow is memory it needs to be hooked to a hot wire on the truck in the harness for the radio that's hot all the time.tThw red hooks to one that is only hot when you turn the key on,or the other way around try that if it still does it switch those two wires. Hope this helps
Nov 27, 2017 | Pioneer Car Audio & Video
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
55973 A EVINRUDE Wiring Diagram IN COLOR FOR Free
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Nov 14, 2012 | Clymer Boating
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Dropped tv and now i only get purple and yellow as the tv colors
hi..It sounds like your tube Shadow Mask may have got
magnetised and need to be degaussed.turn off your TV
at the mains and unplug it for at least two three hours,
after that time power up your TV it should degauss the
tube at power up.
try this out..
thank u..
kindly rate my response..
May 06, 2009 | JVC AV-36260 TV
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Polaroid purple screen
I started to experience this problem as well. Eventually one day I turned my screen on and all the colors were crazy. Purple, Blue Yellow Green. I thought my TV was broken but then I noticed as well that the menu was not displaying the same issue. After messing with the menu for about 30 minutes I found the solution.
Go to SETTINGS. Then go down to DEFAULT. Select default and everything will be fixed.... for now. I think unplugging the TV over and over screwed up the settings. Hope this helps.
Oct 20, 2008 | Polaroid FLM-323B Television
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
455 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
