My washing machine says it needs a service, and says fault code 130. What's wrong with it?
  • 343 Answers
Fault 130 in a Fisher & Paykel washer indicates a faulty Rotaty Position Sensor, or a faulty Motor Controller board.
F&P machines are quite technical and a seviceman should be called so that all components can be tested which interact with the faulty part.
This way you won't be replacing parts which might fail again, and a techs work will be covered by a warranty.
Probably not what you wanted to hear, but the best way to go in the long run.
TIP..... Before you call a tech you should look under the machine and check if there are rusty stains (or even clear water) on the bottom of the flywheel and/or of there are stains on the inside of the cabinet. These are caused by water leaking through the seals being flung from the flywheel onto the inner cabinet. If this is the case you'll need to add new bearings/seals and maybe a shaft to the bill..
Good luck....Nomess
Posted on Sep 06, 2010
Hi Dear My washing machine Fisherpaykel got faults codes 130 what would I do ?
130 is a sensor fault on the main drive motor. I'm not sure if you can purchase this or if you have to get the complete motor.
Mar 21, 2017 | Fisher and Paykel Washing Machines
Last month my aquasmart had fault code 130 payed repairman $180 to fix it now it has fault code 105 your webpage is very unhelpful knowing whats wrong with my aquasmart which is less than 5 years old
Did you look up your manual to help with the problem?
AquaSmart2 8kg - this is a link to download your manual
The good thing is that if you got Fisher & Paykel to come out, they offer a warranty on their service - so call them again and tell them the situation - they should come out for free....
Sep 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Washing machine doesnt wash
Fault code 130 means the RPS (rotor position sensor) is not sending correct signals to the control board. The RPS is a small electronic device mounted on top of the motor copper stator. Either the wiring plug attached to the RPS has corroded the contacts or the RPS needs replacing. You will have to lie the machine down on front face to access the motor. Unscrew the centre bolt and remove the outer rotor bowl, then loosen the 4 hex. head bolts holding the stator about half way. Pull stator down so you can remove the wiring plug from RPS. Check for corrosion. If no corrosion then remove & replace the RPS.
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Fault code 130
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module,
or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted.
Mar 14, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
The model; intuitive eco I need service fault code
RPS fault. this part can easily be replaced. the rotor part of the motor needs to be removed (5/8 socket) then you will see the RPS on the side of the stator. loosen the 4 bolts (3/8), pop it off, replace.
Aug 14, 2013 | Fisher and Paykel Washing Machines
What is a code 240 and a code 130
240. (11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
faulty.
Jun 03, 2012 | Fisher and Paykel Washing Machines
My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
Jan 24, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher and paykel washing machine
Unfortunately, it means get a technician to your home. Something is wrong with the "board". I had the same problem
Sep 01, 2008 | Fisher Paykel Eco IWL16
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Apr 29, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
