Question about iLO (2 GB) MP3 Player
Format problem wont let me select format whhen having flash error
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on May 26, 2008
Have xbox 360 slim since christmas 2010 (so not that old) disk reading error and in memory: says unformatted?!
You can format your hardrive by selecting "Y" and select format disk. Slim have a problem with there Lens, we have encounter issues with them before. your best thing to do is replace the lense.
Thanks
www.1RepairStop.com
Aug 28, 2011 | Microsoft Xbox 360 Console
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
16GB Flash Drive NTFS Formatting
what brand flash drive is this? some of the cruzer brand flash drives are partitioned to 2 drives. you may need to go to the manufacturers website and remove the partition with a 3rd party software. if it IS a cruzer, that software is on the larger of the two drives that show up when you insert the drive.
Jul 11, 2009 | Electronics - Others
PEN DRIVE ERROR
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Feb 03, 2009 | Transcend (589307) Media
Sandisk 16 GB USB Drive wont accept large files says disk is full
What is the USB drive formatted as? Look in My Computer then right click the USB drive, select Properties. See what it says under "File System". My guess is the drive is formatted as FAT32. Now FAT32 has a size limitation of 4GB for a single file, which would explain the error. To get over this you need to reformat the USB drive as NTFS. Then it will accept the 6.95GB file. You can format the drive by right clicking it again and selecting "Format" ... choose NTFS from the drop down menu. Be aware that any data already on the drive will be wiped by the format so be sure to back it up before formatting.
Dec 31, 2008 | Computers & Internet
FLASH ERROR!!!
-Tha Mp3 Doctor
May 08, 2008 | iLO (2 GB) MP3 Player
Flash error
-Tha Mp3 Doctor
Flashdrive
Right click removable drive and select and format the drive. Then scan and fixes all errors. So all the bad sectors are fixed.
In the File System drop down, select FAT
OR
If you right click Removable Drive >Properties
The General Properties of the USB drive reveals it is FAT, so I use FAT in the format utility. Then just select “Quick Format” and “Start” and all data will be deleted and hopefully all errors are now gone.
Feb 08, 2008 | Electronics - Others
M3P player
Flash error means there is a conflict with your storage or play function you want to select format which will erase and reset your mp3 so it will function properly.
after formating the player will then allow storage of music this error can becaused by overloading storage of player or the mususic files are in the wrong format to play
Jan 26, 2008 | TruTech TT320
iLO (2 GB) MP3 Player Logo
20 people viewed this question
Top iLO Audio Players & Recorders Experts
Sanath Kumar V
L Pfaff
L Pfaff
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
