Question about Samson SX1200 Amplifier
Samson s 1500 AMP intermittently shuts itself off
  • Scott Frye
    Scott Frye Sep 07, 2010
    Does this happen after its been on for a while?
    How old is the unit?
    and, have you ever dusted out the insides?
    Power amps are magnets for dust.
    Thanks
Post collision shut off fuel pump sensor
Chevrolet Silverado 1500 Questions - Where is the reset ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusWhere is the reset button for the gas on a 2002 chevy silverado - Please answer. ...Asked by Angie Feb 09, 2013 at 05:31 PM about the 2002 Chevrolet Silverado 1500 ...When you say "gas" the security system shuts off fuel to the injectors.
Electric fuel pump diagnosis: Houston, we have a problem ...
www.autoserviceprofessional.com/.../electric-fuel-pump-diagnosis-houst...
Posted on April 11, 2013 by Mike Mavrigian - Also by this author ... If the vehicle was involved in a collision, impact sensors can kill the pump signal, as well as ... can cause fuel pump intermittent or shut-off problems, when the oil pressure sensor ... 38 fuel lineon my 67 Chevy small block why do I still get fuel pressure drop.Missing: 1500
Impact Cut Off Switch For Fuel Pump? - Ask the GM Technician - GM ...
www.gm-trucks.com > ... > Ask the GM Technician
Apr 7, 2009 - 8 posts - ‎6 authors
posted in Ask the GM Technician: New to the Chev pickup scene. ... Silverado 2500 HD truck would have an impact switch to cut off the flow of fuel to ... Reason for looking at the fuel shut off option was for simplicity on my part. ... your truck is a GMT800 it has a chip & sensor in the key tumbler if its a GMT900 ...
[PDF]Owners Manual - Chevrolet
https://www.chevrolet.com/.../Chevrolet/.../2k13equinox.pdf Chevrolet
Jan 27, 2016 | 2013 Chevrolet Silverado 1500
Reason for burning smell and no audio in my Samson d415
Did it suddenly stop working?
Maybe overload of amp or power supply.
I think you killed you power amp...
Feb 03, 2013 | Samson Auro D415 Active PA Cabinet - 400...
Have a problem with the xp510i - left channel has no output to speaker. Tested with other speaker and cable - appears to be the mixer.
"Tested with other speaker and cable" ... you did not tell us the results of the test. If swapping the speakers and cablles still had the same dead side, it is probably the power amp for that side and not the mixer part. Take in for repair. If you had an accident of speaker cable not being plugged in fully or pulled out while operating, this pops the power amp real quick. They also just plain fail at times. Plug a set of headphones into the MONO out jack. If you can hear audio going through the unit then the mixer is OK... and the power amp on the failing side has a failure. Note the headphones will be low level and probably only one side, usually the left as this is a mono signal and headphones are normally stereo.
Apr 26, 2011 | Samson EXpedition 510i Speaker PA System
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
Every time I use Samson xpl amplifier It shuts off after playing for about 10 minutes do you think what's the problem?
Heat.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Mar 06, 2011 | Samson Servo 300 Amplifier
Need fuses for samson amp
The manual recommends 4 Amp Slow blow for 115 volt operation or 2 Amp Slow blow for 230 Volt operation for the 201a.
http://s3.amazonaws.com/samsontech/related_docs/Servo201a_OM_5L_v1_1.pdf
For the 260 Amp manual shows 10 Amp normal for 115 volt operation and 5 Amp nomal for 230 volt operation.
http://s3.amazonaws.com/samsontech/related_docs/ACF1AAF.pdf
Dec 31, 2009 | Samson Audio Players & Recorders
Can I use my amp with PA speakers?
Yes, but stay within the "ohms" limit of the amp.(probably 4 ohm or greater)
Paul
Jun 09, 2009 | Samson Servo 170 Amplifier
Samson SX1200 Amplifier Logo
48 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
