Question about NetGear FS108 8-Port Ethernet Switch
Why my tv card doesn't work - NetGear FS108 8-Port Ethernet Switch
    Problem Solver:
  • 11 Answers
Posted on Sep 07, 2010
Have a Magtek card reader and doesn't read Emv cards so how do I fix
those readers will read any card with a mag stripe need to have the programing cards to make it work they can be a pain
Jun 02, 2012 | Magtek MT211 TTL TRACK 1 & 2 Magnetic Card...
My TV remote doesn't work. I changed the batteries but that didn't solve the problem.
The remote can be tested and Radio Shack and most repair shops have a simple card for testing---point the remote at the card and press buttons and the strip on the card either lights up or not.
Depending on the problem most remotes are fixable.
Stay away from "Universals" as they are usually trouble.
If batteries and remote test good the set has a receiver for the infrared signal the remote sends-
95% of the time it is the remote and not the receiver or set.
A precise model number would tell me of common issues with your set including the remote.
Mar 14, 2012 | Televison & Video
Playing a downloaded film with HDMI cable to my TV set Sony Bravia, after 10 minutes the colour on tv set disappear or change. Do I need a certain drive on my computer for HDMI
If it was playing the video fine initially, there should be no reason for that to change. Most likely the video card on the laptop is overheating or dying, which results in the change in colors. I fix laptops at my computer repair shop, and most are HP Pavilion DV6000 and DV9000, and they are notorious for having bad video chips on the motherboards. If it is still under warranty I would back up your data from the hard drive then send it in to HP to have fixed or replaced. If it isn't under warranty I would try to connect your tv using just a VGA cable, and see if the same thing happens. If it does, you have a bad video card. If it doesn't happen then you may still have a bad video card, it's just that the VGA signal isn't as high powered/high resolution so your card doesn't get pushed hard enough to malfunction. Try the VGA cable and let me know how it works.
Jun 21, 2011 | Computers & Internet
After inserting my new graphics card my computer freezes on first boot screen
That card doesn't work on that motherboard with that operating system.
Oh wait, we don't know what card you are trying to use, or on what motherboard you are trying to install it or even what operating system you are using....all these details might be nice if anyone here is going to help you!
Jun 17, 2011 | Nvidia GFORCE FX5700LE 256DDR WITH TV+DVI...
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
R92p drivers for windows 7
There are no Win7 or Vista drivers for this card, it's not supported in them since it doesn't have the minimum characteristics necessary for that.
May 01, 2011 | ATI PowerColor R92P-C3S RADEON 9200SE PCI...
I have lg m198wdp monitor tv.problem is white screen
When does it happen?
During Self test? Try this by unplugging the cable that connects to your tower and see if the self test runs. if it does, then your monitor still works. If it doesn't you might need to replace your LCD
During BIOS? If it works then your monitor still works. If it doesn't you might need to replace your LCD
During Windows? then you might need to adjust your display properties or reinstall your video card drivers.
Apr 27, 2011 | LG M198WDP - Flat panel display - TFT -...
Hi i need software for my phillips saa7130 tv card.
Try this driver. If it doesn't work, then please post back.
1. Follow this link for the download page: http://members.home.nl/fly2000/download_e.html
2. Look for "WDM drivers for Philips SAA713x" and click on it to download.
3. Open driver installation package and install.
4. Restart computer if necessary.
Good luck and thanks for using FixYa.
Apr 18, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I inslld agp ati 9550 card,but after instlg drivers,pc doesn boot
something else in your pci slot is interfering with it i had the same problem with a pinnacle tv card and radeon 9550
that agp card is sensative
Dec 24, 2008 | ATI RADEON 9550 Graphic Card
NetGear FS108 8-Port Ethernet Switch Logo
46 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
