Carrier Furnace wouldn't light, fan was running all the time.
Hello:
This furnance has been in the house since it was built. The only thing it's ever needed aside from normal maintenance, was the ignitor was replaced about eight years ago. We've been having rather odd weather for May this year, and I turned the furnace back on last night after it had been off for a couple of weeks. Got up this morning and the house was freezing and the furnace was blowing cold air. Turned it off at the thermostat and it still continued to blow cold air. I had to turn the power off to the furnace because the blower would not stop running. I checked everything out this evening and found that I could not get the blower to stop running and of course it wouldn't light. Checked everything beginning at the thermostat and I found that the manual reset limit switch on the lower right (as you're looking at the furnace) just above the gas manifold, had tripped. I reset this switch, turned the power back on and found that the fan was no longer running all the time. I set the thermostat to check and see if the furnace would light ok, and it did. Flame color is nice and blue and everything seems to be working fine. Furnace cycled off like it should. What would cause this particular reset switch to trip, and what else should I be looking for if the problem re-occurrs? Thanx in advance.
  • helpcal Aug 31, 2008
    i have a carrier furnace model # 58GS075-1 unit lights up no problem, blower motor won't turn off. replace thermostat, still have the same problem. please help. email davisinsyracuse@yahoo.com
    Scholar:
  • 57 Answers
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
Posted on May 21, 2008
3 Suggested Answers
mrgrzz
  • 88 Answers
SOURCE: Ignitor lights gas gas valve shuts off on furnance
thanks for your question, I am mr.grzz,
there are to reasons your furnace is doing what its doing, either a stuck pressure switch, or a bad flame sensor, replacing the pressure switch is pretty easy, its a little round flat peice with a tube sticking out of it, if you take the tube off and **** into it, you will hear a little click, try running your furnace while doing this, if it lites off, then bingo, but you have to make sure you have sucktion to the switch !
now the othe thing that I mentioned is the flame sensor, another relitive easy part to replace, its the pencil thin rod that stick up in front of the burners, when the flame ignites, it impinges on the rod which lets you gas valve stay open, if it has a little buile up on it, it might not send the correct signal back to the gas valve, taking it out, and cleaning it with emery cloth normally does the trick, try that, hope my info was helpfull, thanks again for your question, mr.grzz
Posted on Jan 21, 2009
FurnaceGuy
  • 74 Answers
SOURCE: i can here ignitor sparking but no flame
Can you see the spark? It shoud be around about 1/4" gap. Make sure the igniter is sparking on the burner. Can you smell gas or hear the gas coming on? The pilot if it has one could be dirty or if it does not have one then the main burner cross over may need to be cleaned. Be careful and stand away from the heater while checking.
Posted on Jan 04, 2010
Furnance fan works,but the burnrs won't ignite
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace and look in the small peep hole in the lower blower door and see if there is an led light that is flashing a certain number of blinks record the number and look for a diagnostic chart on the inside of the blower door or the upper side panel of the furnace if there is no flash code present you can try resetting the power to the furnace and see if the furnace will fire up.
Sep 19, 2011 | Heating & Cooling
Air conditioner unit out side is not working. The fan is not moving, and it is flipping our breakers. The furnace is still running - so we are circulating the air in the house. The big unit out side goes...
it could be the compressor or possibly the dual stage capacitor that starts the compressor and runs the fan ,it will be marked with H-for compressor appx35uf./F-for fan at appx 5uf./ and a C-common terminal in the center for the neutral line to both fan and compressor
Jun 04, 2011 | Air Tools & Compressors
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Carrier Performance Boost 80 has a status light flashing on the furnace, 3 times fast followed by 3 times slow. What does that mean?
this indicates fault 33, on inside of access panel will tell you faulty switch. i believe off top of my head is pressure switch open, this a safety switch to verify that inducer fan is working, several things besides a failed part can cuase this, there is a rubber hose going from the inducer fan houseing to the safety pressure switch, remove hose from fan housing and run a small stick ,wire or torch tip cleaner, down the acces port, calcium builds up inside the port and blocks the sampling of pressure, reassemble and try it, if this works add it to yearly maintenance could need new switch or inducer fan motor, these need to be replaced by a tech, also birds can block flue pipe
Feb 02, 2011 | Heating & Cooling
Carrier 38CKC048 unit outside does not turned off when the furnance fan is turned off by the thermostat, I believe its the contact switch that is sticking what part do I need to replace, and can I do it or...
do you own a multi meter? do you know how to use one? if not call some one.
does the unit keep running outside if you turn off the furnace power switch. if it keeps running it the contactor in the condensing unit. if it shuts off it is your t-stat.
May 28, 2010 | Carrier 38CKC048 Air Conditioner
Carrier Furnace Operations
Yes, That is normal for many furnaces, not just the Carrier...
Seems to be a bit dumb but then the ones who desogn these things are sitting behind desks and not out in the field working on them. I'm sure they have a perfectly good reason to have the furnace do that but I have never figure it out....
It does get your attention when the furnace is there running for ever, blowing cold air and burning up your electric....
You just hope that it does not happen when you are away for an extentend period of time...as you said.
Always make sure that if you have someone checking in on your place that they verify the temperature and not just peek in and say yup the furance is running...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Jan 01, 2010 | Heating & Cooling
I have a technical question regarding implementation of my Carrier furnace within my residence. Specifically, the furnance has been installed for 17 years and I have not had any problems with it. I have...
Thats a safety.
The unit senses a failure to ignite, so it goes into safety mode keeping the blower running to prevent overheating and fires. And keeping the inducer motor running to prevent the same, as well as raw gas build up inside the unit.
The newer systems are "smarter" and can detect more specific problems and failures. The older ones simply know that the thing didn't light, so they bring on the fans for safety.
Jan 01, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier furnace blows heat constantly!
recheck your wiring iunside of the furnance around where yuou were working, you may have wired it wrong.
Dec 15, 2008 | Heating & Cooling
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
1,020 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
