Question about Casio FX-260 Calculator
I want to be reminded how to use the normalized function P Q R
How do you unlock the control panel so the " AF " code can be reset ?
After six (6) months of use, the display will show AF. This is a reminder that it is time to change the air filter. The product will continue to function normally. Pressing any key will reset the reminder for 10 minutes. Once the air filter is replaced, pressing the "On/Off" and "-" keys for three (3) seconds will reset the reminder for another six (6) months.
Apr 01, 2016 | Electrolux EI24WC65GS 24" Under-Counter...
Anniversary function
it shall be found some where near the alarm settings..
May 02, 2008 | Sharp Wizard OZ-590A
Light on dashboard saying maint ?
That is a service or maintenance reminder. It is either triggered by miles or time. can just be time for an oil change etc. The dealer normally does the work then resets the reminder. most well equipped shops can reset it after as well. if you diy you would need a obd2 meter to reset it.
Jun 04, 2012 | Toyota Cars & Trucks
I have birthdays listed in my phonebook in the contacts, but when the birthday comes up I do not receive a reminder. please assist.
Usually this depends on the mobile device you use. Some mobile devices are not set to remind automatically while others have that function. Simply go to the reminder service on your device and set the option for birthday reminder on your device once you set this it should work.
Hope this solution has been helpful?
Apr 13, 2011 | Cell Phones
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
Reset water filter light
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place. Let me know if you need the complete manual, Thanks, Sea Breeze
Apr 16, 2010 | Maytag MZD2766GES Side by Side...
Reset filter light
(Select Models)
FILTER
If you want complete service manual please let me know, Oh Please rate Me, Thanks, Sea Breeze
Apr 09, 2010 | Jenn-Air JCD2389G Side by Side...
I changed my water filter and now i need to turn out the filter warning light.
(Select Models)
FILTER
Please rate me!
Thanks, Sea Breeze
Mar 22, 2010 | Maytag MZD2766GES Side by Side...
My 6120c nokia doesn't support the calendar appointment and reminders - always appear a message say "1 reminder or more missed because of change in hours" i stoped the automaticlly time adjastmenet but it...
soft rest your phone then setup your calendar appointments. the reset code is --->
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Nov 15, 2009 | Nokia 6120 classic Cellular Phone
Need a alarm clocl on it or were is it?
Try using Datebook, it isn't exactly an alarm but you can program reminders and apply them daily, work days, multimple days (allowing you to choose which days you want to be reminded), weekly, day per month, or even yearly.
Apr 19, 2009 | Motorola Mobility I335 Cellular Phone
Casio FX-260 Calculator Logo
47 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
