Service manual for a robinson willey gas fire, super eco, contemporary gas, model no D269S
2 Suggested Answers
  • 3309 Answers
SOURCE: wheres the robinson willey service/repair manual
www.robinson-willey .co.uk there site is beeing worked on but there is a e-mail address you can use to ask for a manual
Posted on Jan 18, 2010
My Rheem water heater is giving a ECO failure, How can I fix this?
Question posted under Rheem water heater.
Model number and gas valve are unknown. Add a comment.
Following information applies to typical tank-type gas water heater, and does not apply to tankless water heaters, boilers, indirect heaters, solar water heaters, etc or for electric water heater.
Electric water heater ECO is located on upper thermostat.
Open top cover and ECO can be reset by pushing in red reset button,
Or ECO can be replaced by replacing thermostat. Add a comment.
Open following link to see typical tank-type gas water heater ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
It says if my ECO has tripped the water tempature has exceeded 200F. What would cause the tempature to reach 200F
Question posted under Rheem tank-type gas water heater.
Open following link to see typical ECOs:
More resources:
Sep 30, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Robinson willey topaz gas fire user manual
We have a topaz gas fire and when they came to service it they have pulled the ignition lead off how do we fix this
Sep 19, 2011 | Sewing Machines
Automatic restart is not working. Seems to keep saying eco problem...I thinl...the code is four flashes followed by two flashes.
Gas control valve is not identified, so error code is not known.
ECO means energy cut off.
Energy cut off happens when gas control valve thermostat has gone bad, or when gas control senses runaway heating inside combustion chamber.
Newer heaters have resettable ECO for combustion overheat. This reset is typically located on combustion chamber door and is round and has two wires that connect back to gas control. Generally you have to clean combustion chamber and tubes and catch up on maintenance, then reset ECO, then fire up heater again to see if problem is resolved.
Newer heater does not have reset for bad thermostat, and in that case you replace gas control valve thermostat.
Older heater does not have reset, and combustion chamber and parts are cleaned, and gas control valve thermostat is replaced.
Your manual is best place to start troubleshoot.
Open following link to help identify gas control valve:
Jul 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Can u tell where the reset switch is located i this model or the g91-200
The reset is the ECO.
I can get you started but have not worked on this water heater.
Open following generic manual for Rheem commercial gas water heater:
http://waterheatertimer.org/pdf/Rheem-Commercial-Gas-ECO.pdf
http://waterheatertimer.org/pdf/Rheem-Commercial-Gas-Universal.pdf
Troubleshoot tree on page 20 shows series of tests and actions to restore ECO or determine if gas control valve is bad.
Maintenance steps start page 11. Gas water heaters today should receive yearly maintenance.
Add a comment and say how the problem was repaired.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Rheem GN91-200 Commercial Water Heater
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
I AM LOOKING FOR A MANUAL FOR A ROBINSON WILLEY GAS FIRE JEWEL S 125060 IT IS ABOUT 30YEARS OLD
Hi, if you're still looking for the manual pls contact me at ianb21a@gmail.com
Sep 21, 2010 | Heating & Cooling
Robinson wiley gas fire operation instructions
not sure without seeing the unit , but if you are following proper lighting instructions and the pilot wont stay lit either the saftey valve isnt working or you dont have enough gas pressure if the unit has a themocouple then you may be able to replace the thermocouple. let me know
Dec 17, 2009 | Kitchen Ranges
I dont know what ECO failure means or how to fix it.
This water heater is equipped with a control which has a built inE.C.O. (Energy Cut-Off). The E.C.O. will shut the gas off,
should the outlet water temperature exceed 200 F. If the
E.C.O. has tripped, the entire gas control must be replaced.
For gas control replacement, contact your local gas utility, or a
qualified service technician. The replacement control must be
an identical model to the control which has been removed.
Jan 26, 2009 | General Electric GE SmartWater Household...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
