Question about Olympus TOUGH3000 Digital Camera
My Olympus TOUGH3000 is set on Program Auto and when taking photos in dark scenes of people everyone looks very white, i think the flash may be too strong but I dont know how to change it. Any suggestions?
  • Olympus Master
  • 19,396 Answers
Hi.
To change speed and time of objective opening press menu, so to show P on display.
When P is on display point the camera at the object and press the shoot button HALF and wait for AF becoming green, if AF is red, that means that the camera did not calculate automated optimal values of focus and exposure, and you may get bad picture.
Either than that there is no other automated settings, this is a great camera, but settings allowed are quite basic.
Posted on Sep 06, 2010
How do I lighten the pictures?
Check your camera settings:
White balance should be set to auto,
ISO should be set to auto,
flash should be set to auto,
scene should be set to auto,
Exposure Compensation should be set at 0.
If images are still too dark change ISO setting to 200. If that doesn't work change to 400. If that still doesn't work change exposure compensation to +1. If your photos are still too dark your camera is defective.
Nov 10, 2014 | Vivitar ViviCam 7024 Digital Camera
PICTURES ARE BLACK
6 Ways To Fix Too Bright and Too Dark Photos
Recompose The Photo This is probably the simplest solution. When taking a photo of a scene with very bright and very dark parts, move your camera to eliminate one of the extremes. In the case of the band, I would have either closed the curtains for the shot, or recomposed completely and photographed from the window looking at the band, and the crowd behind.
Use Exposure Lock If you can't recompose the photograph, instead tell the camera what part of the image you would like to see. The rest of the photo will be either over or under exposed (too bright or too dark) but at least you will see your subject. You can dothis by placing the center of the image at your subject; half depressing the shutter to lock the focus and exposure; move the camera to re-compose the image; and fully depressing the shutter.
In the band image, the camera chose to correctly expose the scene outside, but even if the band member had been correctly exposed, the window would have ended up being over exposed and you would just have seen white.
Some cameras have an option called 'spot metering' to set the part of the image you'd like to be correctly exposed. If your camera has this setting, enable it before using the technique above.
Use Fill In Flash If your scene has a sunny background, but your subject is in the shade (or has a hat on), turn on the flash (as I explained way back in tip number 9 - Using Flash During The Day). I know it seems wrong but it really does work! By using the flash, your subject will look as bright as the background. This would have worked well for the child shot above.
High Dynamic Range Imaging This technique is not for the faintof hearted. It requires a subject that does not move; a good camera with the capability to set the exposure and output RAW images. A tripod and image editing software like Photoshop CS3 are also needed.
High Dynamic Range Imaging (or HDR for short) is a technique for placing both very dark and very light areas in the same photo. It requires you to take a number of photographs of thesame scene - each with a different exposure. First take the shot using the camera's recommended settings. Then, in manual mode and keeping the aperture at the same value as the first shot, take a sequence of shots - each shot having a different shutter speed (above and below the original). You'll have 5-9 shots of the same scene all in different exposures.
Merging the three images to the left creates the HDR image below. Thanks to Photomatix for the images.
hdrmerged.jpgNow import these into your favorite paint program. I use Photoshop, but you can as easily use a cheaper program designed specifically for HDR photos like Photomatix. Follow the HDR directions and the paint program will merge these images into one great looking shot!
Use a Filter If your scene is of a brightsky and a dark ground (for instance at sunset, or on a cloudy day), you can use a graduated neutral density filter. This filter cuts out someof the light from one part of the photo (the sky). This will correctly expose the ground and the sky without needing to use HDR. These filterscan be complex to setup, so I don't usually recommend them for beginners.
Fix The Original Photo in an Image Editing Program twobright2.jpgFinally, if you can't take another shot at the same location, you can fix the original image by changing the levels using a paint program. This works best when your subject is darker than the rest of the photo (because cameras lose detail in over-bright areas). I've brightened the band member in the top image using this technique and while it looks okay in thissmall shot, this technique can tend to amplify any noise in the image. The darker the subject, the harder time you will have fixing the image.
I discuss exactly how to use this technique in lesson 2 of my free Image Editing Secrets course. I have a tutorial for Photoshop, Photoshop Elements, Paint Shop Pro and the free Google Picassa.
- See more at: http://www.digital-photo-secrets.com/tip/140/6-ways-to-fix-too-bright-and-too-dark-photos/#sthash.58eENOTt.dpuf
Jul 09, 2014 | Nikon D3000 Digital Camera
I've done something to my Olympus pen epl1! The photos taken with Programme, Shutter Priority, Aperture Priority and Manual modes all have a blueish tinge. iAuto, art, scene modes are all fine. How do I...
I sounds like you have altered the white balance setting somehow. This will be in the setup menus. You want it set to auto. If it is already on auto, then I would think the camera has a fault.
Oct 20, 2010 | Olympus PEN EPL1 Digital Camera
Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
The best situation to use each of the shooting modes
The shooting modes are described as follows: AUTO (Factory default setting) Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. SCENE Scene mode enables you to select one of the following scene shooting modes available in the menu. Landscape + Scene shooting Landscape + Scene shooting is suitable for taking pictures of landscapes and other outdoor scenes. This mode produces clear, sharp pictures with excellent detail, making it ideal for shooting natural scenery. Landscape + Portrait shooting Landscape + Portrait shooting is suitable for taking photos of both your subject and the background. The picture is taken with the background as well as the subject in the foreground in focus. The camera automatically sets the optimal shooting settings QuickTime Movie Quicktime Movie mode lets you record movies. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. My Mode Enables you to make settings manually and register them in the mode dial's mode so you can call up your own shooting mode whenever you want. Program shooting (P) Program shooting allows you to shoot using an aperture and shutter speed that the camera sets. You can set the flash, white balance, or other functions manually. Aperture priority shooting (A) Aperture priority shooting allows you to set the aperture manually. The camera sets the shutter speed automatically. By decreasing the aperture value (F-number), the camera will focus within a smaller range, producing a picture with a blurred background. Increasing the value will let the camera focus over a wider range in the forward and backward directions, resulting in a picture in which
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Best situation to use each of the shooting modes
Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Indoor Indoor mode enables you to take pictures while indoors by allowing the flash to reach farther away. Beach & Snow Beach & Snow mode enables you to take pictures of scenery containing white sand or snow. Cuisine Cuisine mode enables you to take pictures of food by increasing the saturation, sharpness and contrast settings to take sharp, vivid pictures of the subject. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Several shooting modes
The Shooting modes are as follows: Program Auto (Factory default setting) Used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering can be adjusted manually. Portrait Suitable for taking a portrait-style shot of a person. The camera automatically sets the optimal shooting conditions. Landscape Suitable for taking photos of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both the subject and the background. Self Portrait Enables you to take a picture of yourself while holding the camera. Point the lens towards yourself and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the Wide position and cannot be changed. Portrait + Landscape Portrait + Landscape mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Dark pictures
Be sure that you are capturing images in the right shooting mode. For example, if shooting a night scene your image will be underexposed and dark if the image is captured in the Program Auto mode for regular photography, or in any mode other than Night Scene. Be careful that when capturing images, nothing is obstructing the flash.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Dark pictures
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Dark pictures
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Olympus TOUGH3000 Digital Camera Logo
106 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
