When I close my laptop during normal use, Instead of going into hibernation as normal, the screen just goes blank (with the laptop still running). However I cannot resume the computer and have to just turn it off as the blank screen remains. any ideas?
  • 17,130 Answers
Possible fault in your operating system. Open power options inthe control panela nd set time for hiberanation in manual mode. save and exit.
If the fault still goes onto the blank screen even with other power saver options, then the OS must be reinstalled.
Posted on Sep 06, 2010
  • 320 Answers
Hi when you close your laptop it goinng to stand by mode if you press any key it should resume. you can change this options in control panel, power option then go to advanced tab. By the way hibernation need to be enable and is different than normal shout down. if you need more help let me know.
is it help please rate it
regards
Screen goes blank on notebook
u have a problem with your display connections... opening and closing the notepad too many times does that... take it to a techie or surf u tube on how to videos...to change display for acer d150
Jan 13, 2014 | Acer Aspire One PC Notebook
How do I get my laptop out of hibernation?
right click desktop screensaver settings power settings or control panel.
Oct 24, 2010 | HP Pavilion dv5-1000us Notebook PC
Can I run my laptop with the screen closed?
~ on your desktop you can check the display properties [Desktop Screen > RIGHT CLICK on an empty space > LEFT CLICK on properties > Go to Settings Tab then Click the ADVANCED BUTTON] ~ Look for your video adapter chip (usually Intel) ~ Go to Graphics Properties ~ Under Display device you should have 2 monitors there 1 for desktop and 1 for laptop ~ Single display is default, you should select the another one ~ After selecting it, Click APPLY then OK to SAVE the settings.
Jun 17, 2010 | Computers & Internet
Screen goes blank every 30 second, have to hit the
go to control panel > power options. Turn off hibernate and sleep mode, change all settings to never sleep and change the setting for "when closing the lid" to "do nothing" sleep mode, hibernation can destroy the registry on these laptops, you are better off turning that garbage off and just letting it run.
Nov 15, 2009 | Computers & Internet
Blank screen
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Sep 30, 2009 | HP Pavilion dv2000t Notebook
Computer turns on but screen wont
First,If you are running windows vista,This can be due to an update that has your video driver and windows video driver running at the same time.
Hardware would be the invertor board is bad.
Ttry to start with F8 and choose start in vga mode,If this allows you to start normally,go to the device manager and update the video drivers
Feb 22, 2009 | Toshiba Satellite P205-S6337 Notebook
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Feb 11, 2008 | Dell Inspiron 710m Notebook
My laptop wont hibernate!
Typically this indicates a problem with a particular piece of hardware or its driver that is not cooperating when windows tries to hibernate. Do you have anything new attached to the system? If so, try unplugging it, rebooting, and see if it cooperates then. Also, have you checked the windows event log to see if windows reports any particular errors when trying to hibernate?
Sep 02, 2007 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
