Question about Garden
Qualcast hedgemaster 380 hedge trimmer. A twig got caught in the blades and after it was released the motor ran but the blades did not move. Can it be repaired? Dodie
ctf1800
  • 4402 Answers
SOURCE: i have a black and decker hedge trimmer g25?
just take it to a electronics service shop that can resolder it for you
Posted on Aug 05, 2008
  • 313 Answers
SOURCE: (hedge trimmer blades do not
you know what the problem is. it the motor magnetic ring that is
broken. it also called stationary parts of the motor.
Posted on Aug 29, 2008
  • 634 Answers
SOURCE: My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Posted on Jul 09, 2009
  • 76 Answers
SOURCE: I have an electric hedge trimmer and was using it
Hi
sounds like the blades should be sharpen or replaced.
Posted on Jul 16, 2009
bbreton
  • 437 Answers
SOURCE: blades on hedge trimmer stuck or not moving,
There is a pin in the gear that helps the blade move when the engine is running. That pin may be sheared off and may require a new gear.
Posted on Dec 05, 2009
Earthwiseelectrictrimmer
I had a similar problem, with a headg trimmer, it was working fine, just stoped. It did not get stuck, or caught up in anything, on dismantiling, as you say, motor running, no drive.
It was get a new one, or bust, so I put a small tack of weld on gear/drive and reduced fuse rating to 8 amps, (from 13 A) incase I got it jamed, its fine now.
I never could figure how the drive got from a gear to the oscillating leaver, must have been a clutch somwhere inside, anyway, weld sorted that out....
Jun 04, 2016 | Electric Garden
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
My hedge trimmer has a piece of plant caught in it and won't trim
You didn't indicate if it was gas or electric. Either way the plant has to go. if it's electric, see if you can see the fan blade on the motor. Take s small screwdriver and try and turn the motor backwards, which would open the blades. Be careful and dorn't force it and break the fan. Pay close attention on which direction will move the blade.
Jun 16, 2010 | Garden
Bought it today, it just stopped working. Worked beautifully for about 30 minutes. I would think something is caught in the blades, but that doesn't appear to be the case.
Check the blades very carefully! There can be a small twig, wire or most anything in there. Also, plug it into another extension cord to make sure the one you were using is okay. Good luck...Lee
May 29, 2010 | Black & Decker 3.8 AMP 22-Inch Electric...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
