Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
My portable hard disk is not detecting by my PC/Laptop. it's working on other PC/Laptop. and i also installed my hard disk drivers.it also giving beep sounds.
  • Seagate Master
  • 2,219 Answers
The power supplied by the pc laptop on the USB is insufficient to run the hard drive.
If you have an external power supply option on the hard drive, please use that.
Posted on Mar 23, 2015
SHOGUN125
  • 58 Answers
SOURCE: hard disk can not detect and giving beep randomly
Hello there..i have experience with same problem like this...there is two problem with hardisk: first with the mechanic platter inside your hardisk ( you can hear noisy sound from inside HDD) 'cause by wrong prosedure when turn off the pc or problem with chipset on hardisk board (you can see the small green pcb board at other side of your hard disk) touch that board...if feel hot yes there is problem.this problem cause by electrical shock from your power supply unit or you not plugin correctly to hdd power socket.
solution for first problem :
send it to nearest seagate 'cause they have all the parts that you need
solution for second problem:
replacle the board with same tipe and size of your hdd..and it will work again and you can safe your data.but if not...nothing you can do it
Best Regrad
SHOGUN 125
Posted on Jan 30, 2009
suisboy
  • 175 Answers
SOURCE: my portable hard disk drive free agent go 250GB,
did you check the cable? or adapter that they are working fine?
Posted on Feb 25, 2010
  • 30 Answers
SOURCE: cannot read
It sounds almost like 2 things are happening,
1. The drive itself it going out or the board inside that is connected to the drive is bad.
2. or the drive is not getting enough power through the USB ports (or too much maybe?)
I have only encountered the beeping issue on my free agent 160GB when it was not getting enough power to spin up the platters.
If you still have warranty on it. I would HIGHLY recommend you call western digital about it.
Posted on Mar 20, 2010
  • 88 Answers
SOURCE: low beep sound and try on a pc also can not detect it
Check if the warranty will cover this. If it does, they may be able to repair it and keep your data at the same time. Opening it would be a bad idea because that immediately voids your warranty. If you do open it, usually you can find some screws to take out, or they are just snapped together, a small flathead screwdriver usually does the trick for me. Once you get it open, your will still have to find a way to get the data off the hard drive inside (inside is a standard hard drive using a standard connection, SATA, PATA, IDE. Any computer repair place can retrieve that data for you). If you take the hard drive to someone to retrieve the data, the hard drive may possibly be defective. In that case, it is a whole new story and much more money to recover data from a bad hard drive.
Posted on Apr 03, 2010
detour342
  • 200 Answers
SOURCE: my portable HD detect pc, but no driver found and cpould'nt open
If it shows up in my computer then just double click on it as you would the C drive or dvd or cd it should put the driver in already if it is showing remove safely sometimes it will require a reboot after it is installed
Posted on Jul 07, 2010
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Oct 30, 2012 | Toshiba Computers & Internet
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
Notebook does not boot up
Try reseating the hard disk.
If the Thinkpad still does not boot up then go into the BIOS and see if the BIOS detects the hard disk. If it does not detect the hard disk then most likely the hard disk is faulty and needs to be replaced.
Windows then needs to be installed on the new hard disk and the Thinkpad R61 device drivers and your programs to get a working laptop again.
Dec 11, 2011 | IBM Lenovo ThinkPad R61i Notebook
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
My laptop (Acer Aspire 4530) cannot read my portable hard disk. It's say devices not ready & when I click to the icon it's say device not accessible.When I used the other laptop, there is no problem to...
You may need to install drivers for the portable device on the computer that will not read it. Some systems do not recognize other externals if the drivers are not in the directory for the drivers being used. You should have a driver cd for the external so you can install the drivers into the other system. Hope this helps.
Mar 15, 2011 | Acer Aspire 4530-5889 Notebook PC
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
I have problem to install window xp in my laptop, which already have window vista....my notebook donot support to install xp..please tell is there any way to install xp...
What is your problem specifically? Is it that there is no hard disk detected when you try to install windows xp?
Try using third party software to detect the hard disk on your laptop
Try this link. It will basically give you your hard drive driver while installing windows xp. You will also need an external floppy disk drive if you dont have diskette drive in your laptop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70477
Jan 24, 2010 | Computers & Internet
External disk is not been detected
Check the BIOS setting, make sure the hard disk is set to Auto (detect) or change the settings to default settings (your BOS may not have this option) then save and reboot laptop.
If the hard disk has not been detected and/or Unable to find the operating system, it means you may have a faulty hard disk or a faulty hard disk controller or the hard disk may not be making proper electrical connection.
To reseat the hard drive, remove the hard drive and reinsert it into the laptop a few times and see if it boots up..
If it still does not see the hard drive then the fault is probably the hard disk. To test if the hard disk is faulty, remove the hard disk and insert it into a hard drive USB adapter and connect it into the USB port of a working computer. If you don't see this drive as an external drive then you will know its faulty. Then you will need to purchase a hard drive, insert it into your laptop then install the Windows operating system and all your device drivers and programs to get your laptop operational again.
If the hard drive is OK the the fault is with the disk controller, and it is near impossible/expensive to repair the motherboard. Put your money towards a new laptop and put the hard disk into a USB hard disk adapter case and use it as as a portable external hard drive.
Best of luck.
Dec 12, 2008 | Toshiba Satellite M45-S351 Notebook
Having trouble installing
download dial a fix from www.gur.in from thedownload section and than run it and restart the system and try to update
Nov 01, 2008 | Dell Latitude D600 Notebook
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
Apr 15, 2008 | Computers & Internet
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
220 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
