Question about Nikon Coolpix 8700 Digital Camera
Replaced charged battery, turn camera on no response, camera lens is extended, unable to turn on camera, changed battry twince, still no reponse.
  • Nikon Master
  • 17,130 Answers
If the battery you have put is ocnfirmed to have voltage/current in the desired level then the camera is having a power fault within the set and must be opened up. I would advice that this job be done by a Nikon authorised serivce, get and estimate and decide.
Posted on Sep 06, 2010
The camera wont turn on and the lens is stuck in the extended position....not sure if it will charge or not because it isnt turning on. Any ideas ???
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Apr 07, 2011 | HP Photosmart R742 Digital Camera
The lens that extends when you turn the camera on will not extend the whole way and so it shuts the camera down. Any ideas on a fix for this without damaging the camera more? \r\nThanx so much in advance,...
Good day,
Regards
15073327
Mar 25, 2011 | Olympus X-42 Digital Camera
The lens of my DMC-FS20 is not moving correctly (it comes out when switched off and in when switched on) and I am unable to press shutter. A message is displayed telling me to switch off and on again, but...
Good day,
Regards
15073327
Jan 25, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Cannot use the camera at all
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Will not stay on
Will the lens extend when turning on? , can you see any message on the LCD? it is possible there could be a system error or lens error (lens error if jammed all the way in closed position, usually makes the camera shut off right away)
Sep 02, 2008 | Nikon Coolpix L11 Digital Camera
Olympus D-535
well..remove the battries again ..and re insert the battries...
while inseting the battries ensure that u follow the steps given below..
Make sure camera is turned off
The monitor is turned off.
The green lamp and orange lamp on camera is off.
The lens is not extended.
Jun 04, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Nikon Coolpix 8700 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
