Question about Epson Photo Viewer P2000 multimedia player MP3 and Digital Media Players
After switching on it display on the screen "reset". when resetting it was still displayed the same. How can i fix it?
My Bizhub C252 Konica Minolta is getting error C-3451? How can I fix it ?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Jun 28, 2017 | Konica Minolta Office Equipment & Supplies
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
My precore 9.43 starts to run then in 5 seconds turns itself off. Says ERROR- nothing more.
proceed according and fix it. God bless you
  • 2
Jan 25, 2013 | Precor 9.4 Treadmill Motherboard Motor...
Di351 code 510 call technician copier will not run
In the right side the display is located 2 buttons :
one for display contrast and one hole to warm restart switch.
Press the the warm restart switch enter "3" from the 10 key pad when "." appears at the center on the left side of the screen whilw the start up screen is being displayed.Select the particular initial mode function to be set.In your case TROUBLE reset.Touch EXIT on the initial mode screen to go back to the basic screen.
Nov 20, 2012 | Minolta Office Equipment & Supplies
How do I reset my maintenance required light on my 2009 Avalon?
SWITCH IGNITION ON WITH ENGINE OFF.PRESS SMALL ROUND BUTTON ON LOWER RIGHT OF THE SPEEDOMETER UNTIL IT DISPLAY ODOMETER.THEN TURN OFF IGNITION SWITCH OFF.PRESS AND HOLD SAME ROUND BUTTON LOWER RIGHT SPEEDOMETER TURN IGNITION TO ON WITH ENGINE OFF.CONTINUE TO HOLD BUTTON FOR AT LEAST 5 SECONDS UNTIL IT DISPLAY INDICATES 000000 AND MAINT REQUIRED LAMP WILL EXTINGUISH.RESETTING IS COMPLETE.
Oct 19, 2010 | 2008 Toyota Avalon
The inside screen of the sch-u740 is just white...is there a way to reset or fix?
Hi, when a screen displays white,is when the screen of the phone is damaged that's when is shows white display.
To rectify this screen problem, you will need to replace the inner screen of the phone and the phone will display again.it is not a reset problem, but a screen problem.
Take care.
Sep 26, 2010 | Samsung SCH-u740 Cellular Phone
How to reset the phone if do not work reset switch and screen display serial v2. 05
how to reset the phone if do not work reset switch and screen display serial v2. 05
Jun 20, 2010 | T-Mobile MDA III Pocket PC
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Epson Photo Viewer P2000 multimedia player MP3 and Digital Media Players Logo
29 people viewed this question
Top Epson Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
David Tickner
Are you an Epson Audio Player and Recorder Expert? Answer questions, earn points and help others
