My Xerox Workcentre pro 245 show me this problem: 10-530 06-25 The Fuser Module is not compatible with this machine. Replace the Fuser Module. Printing is disabled. Can you tell me how can I replace thist fuser module?\ Thank you very much
  • 208 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset.
Posted on Dec 03, 2007
  • 53 Answers
SOURCE: Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Posted on Jan 26, 2008
  • 14 Answers
SOURCE: Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Posted on Feb 13, 2008
SOURCE: Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Posted on Apr 22, 2009
  • 990 Answers
SOURCE: CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Posted on Jun 05, 2009
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Printed pages count
on the 416, click on the "machine status" button next to the lcd screen. scroll down to number 09, which is "Total Print Counter".
Nov 28, 2009 | Xerox WorkCentre Pro 416DC Copier
I need the manufacturer part number for the fuser to a WorkCentre Pro 580 - Xerox.
Call 1-800-828-5881 and follow the prompts. They will give you the part number you need.
Dec 15, 2008 | Xerox WorkCentre Pro 580 Plain Paper Laser...
My machine shows a U4 code
U4 code refers to a fuser heat failure, you'll probable find the fuser roll is stone cold .Possible cause is open circuit heater or overheat thermostat popped.Either way you will need to pull out the fuser unit and check continuity of the components
May 29, 2008 | Xerox WorkCentre Pro 423 Copier
151 people viewed this question
k24674
