Question about Whirlpool RBS275PD Electric Single Oven
Oven will not work at all after clean cycle
After a clean cycle, the oven will not get hot at all (in any mode) it will not even go into a clean cycle again.  the control panel is working the same as it did. i can feel air comming out of the front vent (not hot at all)
what do you think the problem is
thanks in advance for your advice.
tk
The same exact thing happened to me on an RBS275PDB8
    President:
  • Whirlpool Master
  • 2,651 Answers
Theres athermal fuse located on the rear of the unit sounds as if its gottren to hot and opened for safety reasons, you see its a quarter sized thermostat with 2 wires leading to it usually on the upper middle of rear cabinet betwwen the broil elemnt hookups, TURN OFF PWER BEFORE CHECKING LIVE WIRES
Posted on May 13, 2008
I have the same problem. But, after replacing the thermal fuse, the next time I cleaned it, the fuse blew again. I think the clean cycle is getting too hot, due to a problem with the circuit board. I'm not wanting to replace the circuit board till I'm sure, and I don't know how to be sure.
Posted on Jun 27, 2008
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Tip
Self Cleaning Oven Problem
Before you choose to run you oven in the “Self Clean” mode be sure to read this.
After viewing many hundreds of range and oven problems there is one constant theme that comes through. “After running the self clean feature” on my oven I have this problem or that problem. Whether the oven is gas or electric does not seem to matter. The common thing is that the self cleaning feature was just used on the oven, and now it is not working, the glass broke, or you now, cannot even get the door open.
The basic idea of a self cleaning oven is to get the oven so hot that you incinerate everything that is in the oven. The heat from this process will burn up everything in the oven and sometimes things outside also. Even though the wiring and controls are built to withstand high heat, taking the oven to such high temperatures pushes everything to the limit. If something is not insulated perfectly or has shifted a bit then the heat causes it to fail. Repeated heating also wears the insulation out and causes it to break down. For this reason the self cleaning features should be used sparingly.
Manufacturers want to please the customer so even though they know that this can create problems they also know that this feature sells more products. It is in your best interest to not even use this feature if possible.
If you have a oven that will not unlock after the cycle you have a few things you can try.
First make sure that you wait long enough before you try to open the oven. If it has not cooled completely it will not open. Do not run a clean cycle when you do not have the time to let it cool completely before you need it. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and it will open. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jan 25, 2010 | Ovens
I cleaned (auto clean cycle) and now there is a beep and F-2 flashes on the panel. Door is in lock mode and still very hot. What does F2 mean?
Means it is sensing that the oven temperature is above 915F-930F. Check the door lock switch.
Feb 28, 2011 | GE Ovens
My oven display has a error display of E5F7,oven too hot.. The doors will not open. They are locked in the self-cleaning mode. How can I open the doors or can I do something to override or reset the the...
This problem is caused by defective material in the core
of the solenoid on the door latch. The solenoid works
properly at normal temperatures, and at the beginning of
a self-clean cycle. However, when heated, the plastic
core binds the metal plunger, and will not allow it to unlock
at the end of a cycle. Once cooled, the solenoid will
again work properly. When a technician inspects the
solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Jan 26, 2011 | KitchenAid KEBC208 Electric Double Oven
Self-clean cycle not working
the first problem may very well be your control board and or as they call it a clock timer.while the unit is in the cleaning mode you need to check the power from the control board to the elements, you may also have
Jan 31, 2010 | Ovens
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Same with mine I was just told it is the control panel needing replacement.... $$$$$$$$$$$$$$
Oct 11, 2007 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
117 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
