OUr Rinnai gas heater convector 516tr keeps on turning itself off and flashes 12 on the light panel. What does that mean and how to fix it? tks
  • 19,396 Answers
Hi.
12 flashes means "Incomplete combustion". The code is prompted when the flame turns off because of a problem.
Check filter, check gas pressure and thermocoupling. Those are the problem that commonly trigger the code 12 error.
Here a manual.
Here Fixya thread on the problem.
Posted on Sep 06, 2010
506 convector rinnai
if the flame does not start at all, so just ticking from the ignitor you have a main valve problem and this is expensive replacement part and it must be done by a trained gas fitter.
May 21, 2014 | Heating & Cooling
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
Converting rinnai 516tr from natural gas to lp
Try national energy they sell convestion kits It would need a gas fitter to do the work , you may need to a quote on this , they would be able to tell you if it is worth it ,its hard to tell with out looking at the heater .
Feb 24, 2012 | Rinnai Heating & Cooling
I have Rinnai natural gas room heater 516tr. It's continuously showing filter light on indication. I have clean heater but still filter light kept on. What I should do?
Turn the heater OFF and unplug it from the wall. Remove the filter and reinstall it, making sure it's fitted properly into the heater. Wait 5 minutes and plug the heater back ion and turn it ON. You may have to reset the controls back to way you had them. Completing what you just did, should have allowed the heater reset itself and function as it should. If this sort of thing continues to reoccur, contact your local Rinnai Dealer for service.
Hope this helped you to solve the problem.
May 01, 2011 | Heating & Cooling
Hi i have a rinni convector 516tr heater i put it on it switches off a few seconds later i think it has to do with the timers i have lost the book/
I am assuming this is a tankless heater. Are you turning the water on full throttle and is there full flow. First thing to check is the small filter screen on the inlet of the water heater. If the flow is reduced the water heat will not fire.
Sep 05, 2010 | Rinnai Heating & Cooling
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Convector 516TR Heater
Hi, Here is the link to the manual. I think something like 'thermo coupling' probably means you need a technician!
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/153.pdf
Jun 24, 2008 | Heating & Cooling
Rinnai Heater - error message "12"
An error code of 12 on your heater means a flame failure has occured. It could be the following: Flame Rod dirty, Obstruction in burner, improper gas pressure, or a bad ignitor board. I am suggesting you get a technician who is familiar with Rinnai products to check out the above items.
May 25, 2008 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
668 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
