Question about Miele Dishwashers
Hi, We have a miele G1220scu dishwasher. It is currently displaying error message F84. Can you please let us know how to fix it. Kind regards, richard.
SOURCE: Miele GS2220 Sci error message F84
Call Miele they will send a copy of the instructions booklet, I did and I got one
Posted on Apr 23, 2008
  • 122 Answers
SOURCE: Miele dishwasher stopped, F84 flashing please
In most cases this means the circ pump is faulty - suggest calling a Miele service rep
Posted on Sep 23, 2009
  • 177 Answers
SOURCE: Miele Dishwasher does not start
hi,
F51 fault is more than likely the heater relay is faulty but it could be your circulation pump is jammed up. if you are confident you can easily replace the replace the relay if it is faulty. you would need to put a meter across the terminals. if it is ok then the pump is blocked. if you are not confident you would require a service call. Miele have there own deadicated service team if you live in a metro area
hope this helps.
Posted on Apr 25, 2010
SOURCE: F84 Error code Miele
I have an F 84 error on Miele G1220 .
I have cleaned the non-return valve and there are no foreign objects that I can see restricting the impeller.
Is there anything else I can do?
There is a stainless steel metal solid tube on the opposite side from the non return valve, under the filter combination. intrying to make sure everything was free, I have inadvertantly pushed this back into the casing . I hope his has not caused a further problem.
Vernon
Posted on Jun 18, 2010
  • 70 Answers
SOURCE: f84 error on miele dishwasher G2534SCI
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F84 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
The motor will have to be removed be sure
Posted on Feb 01, 2011
F84 error on miele dishwascher miele g2530 sci
There is a slide valve in the machine that directs the water to the upper and lower arms. The valve can become plugged or the signal to it can become lost. The machine is not an easy one to repair and you can do more harm than good if you don't know what you are doing. To give you an idea, you have to remove the machine and turn it upside down to work on it.
Apr 18, 2015 | Miele Dishwashers
Hi, I have a problem when you turn on dishwasher MIELE G1730SCI after a minute fault F84 is displayed, what could this mean?
First thing you can try is to shut off the power to the dishwasher. If that doesn't do it then you have a bad board.
May 13, 2011 | Miele Premier-Plus Built-in Dishwasher
F11 appears on the display ?? what can that be from.??
water outlet is restricted,water remains in the cabinet at the end of the cycle page 46 of your manual tells how to fix this error by reading under the care and cleaning section of your machine http://www.miele.co.uk/products/manuals/dishwashers/G1220_1230_2220.pdf note this is an older model then yours but the error codes have not changed nor has the cleaning part if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations Thanks Rick
Mar 15, 2011 | Miele G2470SCSFSS Dishwasher
F84 error on miele dishwasher G2534SCI
Hi
Jan 14, 2011 | Miele Premier-Plus Built-in Dishwasher
I have a MIELE with a " F84 " falt code please help Thanks Phil
Hi
Aug 04, 2010 | Miele G848I Dishwasher
What meens the problem F84 for miele dishwaser?
Hi
Jun 10, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher stopped, F84 flashing please help. Maureen
Sep 02, 2009 | Miele Dishwashers
Where to add the salt
I have just moved in to a property with a miele dishwasher model no. G1220SCU. I have not been able to locate a manual and it also requires salt to be added
Oct 27, 2008 | Dishwashers
This problem arises because the water inside the washer cannot get out.
Firstly......Make sure the salt cover if screwed on tightly (if you have one).
Then remove the filter(s) from bottom of the washer and clean.
Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.
Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Jul 27, 2008 | Miele Premier-Plus Built-in Dishwasher
Nov 18, 2007 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
