Question about Roxio MYDVD VIDEO LAB 10 for PC
Hi there, i'm having problems trying to import mpeg files from my Hitachi DVD camera to my PC using Roxio MyDVD video Lab. It captures the 1st chapter of the movie fine, but for any subsequent chapters it only captures about 2 seconds each. The play preview shows the whole chapter, but when imported you only get a brief snaphot. I have tried this with several different chapters and all the same result. There is also a problem where, when importing a scene, it gets to 100% imported and then freezes. I then have to close the programme down using task manager, which still shows that the programme is 'running'. Very frustrating indeed! can you help? Thanks Stew
  • 4 more comments
  • tgwonda Sep 06, 2010
    Using the live USB connection. We got Roxio because the programme that came with the camera was misplaced, so it's the only way we can get the film from the camera to the computer.
  • tgwonda Sep 07, 2010
    Hi there, I'm not using firewire but i see there is a port for one.
    I'm using a Dell Studio Intel core 2 Duo CPU, T6600 @ 2.2 Ghz. 4GB RAM. SO should be grunty enough no?
    Cheers for the reply mate.
    Yep DVD cam Model no. DZ-MV780E.
    Aah! back to the original problem. Hitachi do not provide that programme after market. There is only 1 programme licenced to each camera and that's it. So they recommended Roxio. Using Panasonic 1.4Gb DVD Ram's.
    Oh sorry bro. DIdn't mean to dis you at all, I appreciate the help. In fact I hope you're right, as the other guys solution will put me back to square 1! I'll go right out and get a firewire and hopefully all my woes will be over. cheers Bob!
    you'd think so but for some reason Hitachi don't give away the programme that comes with the camera, they recommended that i buy Roxio. cheers for the other tip though
    Genius:
  • 1,354 Answers
Hi
you have a prob with your software if your using lice vision the just send me on customer support for the video lab company from there only you will able to find solution
if your not using license then try this with Media recorder
Posted on Sep 08, 2010
    Guru:
  • 1,051 Answers
Use the Hitachi software to first download the movie to your PC, then open it in Roxio and do the editing you want. I've had problems with Roxio and replaced it with Cyberlink Power DVD. Another good alternative is AVS4you. AVS4you is the least expensive and can do alot. Get a fully functional trial copy first at www.avs4you.com
Posted on Sep 07, 2010
  • 1 more comment
  • Bob Korsu
    Bob Korsu Sep 07, 2010
    I should also have suggested that you check the hitachi web site for any software upgrades for your camera.
  • Bob Korsu
    You should be able to download the misplaced software directly from Hitachi.
  • Bob Korsu
    Bob Korsu Sep 18, 2010
    I've found that using the AVS software most USB issues go away. It'll slow down the transfer, but you'll get what you want.
  • 3,153 Answers
It sounds as if you are using USB for the transfer and this has limitations with regards quality and the amount you can tranfer in one block.
The best option is if your player supports firewire (1394) then use that as the limitations do not apply and it is also faster.
Other limitations are down o the spec of the computer and wihtout those there is litle more advise I can give
Bob
  • Project NOMAD
    Project NOMAD Sep 07, 2010
    Your computer has enough grunt as you say so your issue is with the USB port for sure !
    Roxio will also work with firewire connections too.
    Your USB port has a limit !
    Also using firewire will l;et you pull the WHOLE video and not just parts.
    You can also use the built in microsoft stuff to do your movie too.
    I can see you are going to diss this answer as you did the last and thats fine but your USB port is the issue and there is NO WAY round that as it is a built in limitation of USB.
    There is plenty of FREE editing software and even expensive software but they are all going to give you the same issue using USB. I can only speak from first hand experience on this issue.
    Feel free to drop this answer but I am sure you are going to be told again by any other GOOD expert with experience in vidoe transfer that you have a USB issue
  • 3,247 Answers
Might be helpful if you explain how you are grabbing the video output from the Hitachi DVD. Is it using the live USB connection or do you have the DVD created on the camera and then you are playing it in the DVD player of your PC running Roxio.
Is there a way to copy the DVD first into a the PC hard drive and then apply the Rixio for editing etc.
Posted on Sep 06, 2010
  • Sam Sep 07, 2010
    Are you able to provide the model no. of your DVD camera?
  • Sam Sep 07, 2010
    Thanks for providing the model no. of you hitachi DVD camera. I have gone through the user manual.
    I have looked at pages 142 onwards on PC connection. I think you will need the software that is available for this camera due to the nature of the format used by the DVD which is different to the DVD format used in PCs and other DVD players. Also see information on this site for your model DVD camera.
    My suggestion would be to obtain the recommeded software from Hitachi (check contact number in manual) and try out according to instructions given in the above documents. Keep in mind that Hitachi have now stopped making video cameras.
    Roxio MyDVD etc may not be compatible with the format. Which type of DVD discs are you using?
WHY MY DVD NOT BURNING
Using Roxio Video Wave 2011 on HP laptop windows 7 (3 months old)
I created a new Production using pics and mpeg2 files from sons baseball team.
This production is 45 minutes.
Now I would like to create a dvd for kids and parents.
I selected Output > Send to MyDVD
I selected Standard Definition DVD.
Another windows appeared called Roxio MyDVD.
I created a basic layer and no sub menus.
I selected Preview Project and it plays wonderfully.
Then I selected Burn Project button.
Burn Project window appeared.
I place a Sony DVD+R into the drive.
I selected 8X speed.
I select Burn to disc and save disc image file (.iso)
When Encode movie and menu process is over, the DVD is blank.
Hotmail Support ' Aol Support
Apr 09, 2013 | Samsung DVD Burner SATA Model SH-224BB -...
I have bought a cannon XH-A1 HDV camera but find i cannot capture scenes using Pinnacle Studio plus v9 could you please advise me on what is required, may be studio 11 plus for windows XP will solve this?
Hi there
Pinnacle Studio Plus V.9 can only be used for editing DV and not HDV however Pinnacle Studio Plus V.11 can be used to edit both DV and HDV.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Cameras
Roxio mydvdv video lab 10 serial
Please download the Roxio.MyDVD.Video.Lab.v10torrent from the link provided below :
http://thepiratebay.org/torrent/5821474/Roxio.MyDVD.Video.Lab.v10
Download the Torrent software from the link provided below :
http://www.utorrent.com/downloads
Jan 05, 2012 | Roxio MyDVD Video Lab 10 for PC
Manual
The manual is built into the Help section of the program. Also, once you register the program at Roxio, you can go into the support area for the product, and access theur entire Knowledge Base and FAQ's. But you have to be a registered member first. You can go here to register http://www.roxio.com/enu/support/default.html?rTrack=m_sup
May 26, 2010 | Roxio MYDVD VIDEO LAB 10 for PC
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
I have spent MANY hours developing a nice video. When I go to burn to an image file I get an error message: "Encoding Error 8004520c". I have tried many times. I have defragged. Updated video and...
Here You can find a free mpeg converter for any type of files. What kind of file do You have? If it's .avi, probably Roxio creator cannot burn it because it is too big, and if You nave the menus on Your future DVD, I'm sure the reason is the size. On Mac it's easy. With toast titanium, You can select an option fit-to-DVD, and the video fits on standard DVD. Probably, the default compression options in Roxio aren´t sufficient. Try to search in advanced options compression level, or, You can convert with the MPEG Streamclip the video to mpeg video, by selecting a different level of compression, and then You can offer this file to Roxio. Try this. If it not helps, drop me a message.
Sep 10, 2009 | Roxio Creator 2009 for PC
DVD keeps jumping
There may be a problem with incompatibility between the make of DVDs you are using and your DVD player. What make of DVDs are you using? Not all DVDs are of equal quality, Verbatims and Tayo Yuden are considered among the best., Maxell, memorex and store brands are at the bottom of the barrel.
Also how long in time is the video on the DVD?
Aug 25, 2017 | Roxio MyDVD Video Lab 10 for PC
How do I capture video from my jvc video camera
i think best softwate to use is Pinnacle Studioand you will need to get the video to computer convter
Mar 12, 2009 | Roxio MYDVD VIDEO LAB 10 for PC
I have problem importing videos to my computer using (Roxio MyDVD for Canon)
be sure that you installed the cd driver camed with your camcorder and also try using ULEAD MOVIE MAKER as im using now with my camcorder. its very easy to use. hope that helps!
CHARCOIS
Sep 24, 2008 | Canon DC10 DVD Camcorder
Video Recording in Canon DC20
U can use Nero, where you create your own dvd, click on import disc. There will be a item, select it and click import disc. The file will be stored at the default nero folder witch usualy is under "My Document's" an then under "Nero" then "Imported" then a folder wih the date of import will provide you with the videos. This is how i did it until it started to eritate me, because your dvd should not be scrached in any way, the program will terminate if it cant import that piece of video.
I hope this could help you...
Aug 11, 2008 | Canon DC20 DVD Camcorder
Roxio MYDVD VIDEO LAB 10  for PC  Logo
73 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
