Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
HOW TO PARTITION FREE AGENT 500 HARD DISK. i HAVE NO PRIOR EXPERIENCE AND WOULD LIKE TO ENSURE EXISTING DATA IN FREE AGENT REMAINS INTACT. pLEASE ADVISE
  • 922 Answers
First, copy all of the data from the drive to another as a backup.
Now the drive already has a partition or you would not be able to store data on it. Therefore, you could only be speaking about dividing it into multiple partitions.
Therefore you delete the exisiting partition and then create smaller partitions. In Windows you will be limited to 4-partitions.
I hope this helps.
Posted on Sep 06, 2010
I want a free registration key for card recovery v 6.10 build 1210
Let try Cardrecovery 6.10 Build 1210 + Lifetime Crack Registration Key By Keyguru.blogspot.com
http://keyguru.blogspot.com/2013/06/Download-Cardrecovery-610build1210-with-key.html
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
I want to remove my patition
Perform the following steps which dddriver mentioned
But deleting partition means that your data will be lost from that volume.Its better take the backup of data otherwise your data get lost. To retrieved your data from deleted partition with the help of partition recovery tools. These tools are absolutely safe on the data in the drive and their only concern is to get back the lost data without altering the format.
Jun 13, 2011 | Computers & Internet
My note book stopped recognizing the hard disk model no. HS122JF from samsung
Form my experience it's a early sign of any issue in Hard Disk circuit. It'll be best if take backup of your data and take the hard disk to a hardware technician as early as possible. Otherwise you may loose your data.
Mar 15, 2011 | Samsung HS122JF 120 GB Hard Drive
I bought a Seagate Free Agent Desk External Hard Drive 500 GB for use with Windows. I Have an iMac and wish to reformat it for use on my Mac Operting System Version 10.6.4 (Snow Leopard). Please...
In Disk Utility click on the Partition click on the Current Volume Scheme drop-down menu and select One (1 partition) from the Partition Schemes provided: Click on the options button and chose either the GUID Partition button or the Apple Partition Map button click OK Select other options as desired (e.g., Volume Name Format etc.). Click Apply the Partition Disk screen opens click Partition
Time Machine may open asking if you would like to use the volume for backups. Click Cancel to proceed
Oct 21, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
Aug 17, 2009 | HP Pavilion dv6-1030us Notebook
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
Format the partition by using the NTFS file system (Quick)
Format the partition by using the FAT file system (Quick)
Leave the current file system intact (no changes)
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base:
Oct 19, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
165 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
